Author Topic: does a 1994 2.0 exhaust manifold fit my 1.6 idi?  (Read 4460 times)
January 21, 2013, 01:48:43 pm
wdkingery
  • 494
« on: January 21, 2013, 01:48:43 pm »
Yes it does. Thanks for picking up the phone Lucas. You saved me a bunch of time.
Reply #1January 21, 2013, 07:04:08 pm
tyb525
  • 183
Re: does a 1994 2.0 exhaust manifold fit my 1.6 idi?
« Reply #1 on: January 21, 2013, 07:04:08 pm »
So, why did you want to put a 2.0 mani on it? Interested to hear your thoughts
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #2January 21, 2013, 09:26:38 pm
CrazyAndy
  • 739
« Reply #2 on: January 21, 2013, 09:26:38 pm »
Probably to get it to fit into the car without having to drop the entire exhaust.  That's what I would have done anyway.
Reply #3January 22, 2013, 08:08:39 am
wdkingery
  • 494
« Reply #3 on: January 22, 2013, 08:08:39 am »
I had the toilet bowl style exhaust.. And it was leaking all over the damn place, comprising my in cabin air quality. At a stop light, I had more smoke coming from under the hood then I did out the back of the car! So the only way to fix it was a gasser manifold, but the only one available to me was a 2.0.
Right after that repair, my alternator fell apart..?
« Last Edit: January 22, 2013, 08:19:58 am by wdkingery »
Reply #4January 22, 2013, 10:19:42 am
tyb525
  • 183
« Reply #4 on: January 22, 2013, 10:19:42 am »
Did you try replacing the gasket on the manifold where is connects to the toilet bowl? Mine leaked pretty bad too, but I replaced that gasket and it's good now.
I think when the engine shakes around a lot it compromises that connection. But then I don't think that would be good for a solid connection either like the gasser or pre-81 bolt-on style manifolds.
Reply #5January 22, 2013, 09:24:35 pm
« Reply #5 on: January 22, 2013, 09:24:35 pm »
the manifold off a 2.0 ABA is a much better designed unit tho, and will perform much better..
Reply #6January 23, 2013, 09:01:57 am
wolf_walker
  • 1205
« Reply #6 on: January 23, 2013, 09:01:57 am »
Is the downpipe laying on the steering rack in that photo?  Rattle Rattle....
Good idea though.  I've got an old GTI dual down on my NA'd 1.9.
Mentat Text Two
Reply #7January 23, 2013, 10:38:04 am
wdkingery
  • 494
« Reply #7 on: January 23, 2013, 10:38:04 am »
Yeeeeah i was kinda past just putting a gasket on it.. the C clips were all bent out of shape from the entire exhuast hanging from the manifold.  I needed something more substantial
You know i got a 5 mph higher top speed on hills and stuff after i put this thing on. now i don't know if it's related to the bitter cold we had this week, or the manifold.. but my car likes somethin better.
it is sooo close, but does not hit it!
Reply #8January 23, 2013, 01:22:43 pm
« Reply #8 on: January 23, 2013, 01:22:43 pm »
once your motor mounts settle more, it will rub..
the header on my GTI hit the rack, so my solution, was to cut some 1/4" aluminum spacers, and slip them under the rear engine mount, and the trans mount.. it effectively lifted the back of my engine just enough that the header clears everything nicely..
Reply #9January 26, 2013, 05:44:37 pm
jaed_43725
« Reply #9 on: January 26, 2013, 05:44:37 pm »
So knowing this couldnt someone get a tubular turbo manifold for a 2.0ABA and use that?
Reply #10January 26, 2013, 06:32:14 pm
« Reply #10 on: January 26, 2013, 06:32:14 pm »
sure, but you wouldnt be able to run an intake manifold ;)
gotta remember, the ABA is a cross flow, and diesels are NOT.
