Author Topic: Fuel Filter Setups  (Read 5090 times)
Reply #15January 13, 2013, 03:10:15 pm
Re: Fuel Filter Setups
« Reply #15 on: January 13, 2013, 03:10:15 pm »
It's not pipe thread.  The die was kind of expensive.
x2 not pipe thread...
Reply #16January 13, 2013, 04:22:49 pm
RustyCaddy
  • 395
« Reply #16 on: January 13, 2013, 04:22:49 pm »
Here is a link for a pipe made in Europe that talks about the thread size (but pricey):
http://www.ebay.com/itm/Eckes-WT-Adaptor-heated-fuel-filter-vegetable-oil-SVO-biofuel-WVO-Pol-/261153321283?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ccdf37143
The oil cooler setup is really a smart way to go.
Reply #17January 13, 2013, 06:18:58 pm
« Reply #17 on: January 13, 2013, 06:18:58 pm »
Why do VW and Bentley recommend replacing the heat exchanger any time  you have the motor apart?
Even the $360 OEM unit was leak prone 3 ways form Sunday, but the cheap knock offs are cheaper.
I paid about $60 to remove that stinking thing from my engine bay.
If you need a bolt, you can get one from any Volvo or VAG car at the scrapyard with a similar cooler.
Reply #18January 13, 2013, 06:31:44 pm
RustyCaddy
  • 395
« Reply #18 on: January 13, 2013, 06:31:44 pm »
The tube for the oil cooler is a different diameter than the used for the fuel filter...the Eurospec adapter solves that issue if you want to use a stock fuel filter.  if you have a 3/4 16m fuel filter assembly you can use a Baldwin fuel filter.  i believe this was the setup used by Frybrid, which had a very good reputation for reliability (the owner not so much).
i guess VW was thinking about warming/cooling motor oil not vegetable oil when they recommended replacement intervals
i paid about $60.00 when i installed my oil cooler to my NA; people look at things the way they do.
