Author Topic: Harmonic damper  (Read 4752 times)
Reply #15December 25, 2012, 11:02:55 am
Re: Harmonic damper
« Reply #15 on: December 25, 2012, 11:02:55 am »
my aaz flywheel weighed 12.8lbs stock. IIRC around 9lbs and under it is getting really bad.
12-13 is stock.. they do make heavy flywheels tho, that are 19#, and have a much thicker ring in front of the ring gear..
Reply #16December 25, 2012, 04:48:29 pm
Gizmoman
  • 1301
Re: Harmonic damper
« Reply #16 on: December 25, 2012, 04:48:29 pm »
I only started to notice this when I went from the 190 diesel clutch to the 210 gasser
. . . That's where I'd start lookng
Reply #17December 27, 2012, 02:37:42 pm
Re: Harmonic damper
« Reply #17 on: December 27, 2012, 02:37:42 pm »
i would think that your clutch/pressure plate/flywheel is the issue..
too light of a flywheel will give these things some pretty funky harmonics as well. didnt you install a 6#, or 9# wheel?
