Author Topic: Transmission linkage needs rebuilt.  (Read 7760 times)
Reply #15January 14, 2013, 07:14:13 am
Re: Transmission linkage needs rebuilt.
« Reply #15 on: January 14, 2013, 07:14:13 am »
they are angry little springs.
True dat.... I rekon they could easily break a finger if they hit u right, coming off.
The muffler clamp really is about as good as the official tool. (I have both.)
amazing the force those things will exert, isnt it?!
must be a pretty amazing alloy, to be able to stand up to that kinda heat and vibration!
Reply #16January 14, 2013, 07:36:15 am
« Reply #16 on: January 14, 2013, 07:36:15 am »
The clamps that I have seen are wedges, I think. I would like to make a spring expander with a screw thread. I don't like pounding on strong springs. It goes against my sensibilities.
Ror20 what kind of clamp are you talking about?
Reply #17January 14, 2013, 07:49:35 am
« Reply #17 on: January 14, 2013, 07:49:35 am »
the spring clamps used to hold the exhaust system to the downpipe/manifold..
Reply #18January 14, 2013, 08:06:04 am
« Reply #18 on: January 14, 2013, 08:06:04 am »
image ctsy "cubevandude"
Reply #19January 14, 2013, 08:15:02 am
« Reply #19 on: January 14, 2013, 08:15:02 am »
Thanks for the pic.
Reply #20January 14, 2013, 08:17:39 am
« Reply #20 on: January 14, 2013, 08:17:39 am »
I meant clamp expanders not clamps.. My proof reader didn't catch that. :)
Reply #21January 18, 2013, 11:22:07 pm
oldpoopie
  • 46
« Reply #21 on: January 18, 2013, 11:22:07 pm »
I used the USRT kit and it is awesome. Makes my crapbox actually fun to drive.
GENIUSPACK2 Master Kit
http://www.usrallyteam.com/index.php?main_page=product_info&cPath=13_34&products_id=1763
1985 jetta TD. It was free, and it shows. Down and dirty engine refresh made it run fairly well.... No leaks, except water into the cabin!
2001 golf Tdi. Heavy built ALH, soon to have a PD Frankenstein motor.
Reply #22January 19, 2013, 06:17:57 am
« Reply #22 on: January 19, 2013, 06:17:57 am »
I bet it helped. What size spherical rods do they use? I am thinking of using similar parts on the shifterleg itself. Something like this:
Reply #23January 19, 2013, 06:46:18 am
« Reply #23 on: January 19, 2013, 06:46:18 am »
Both of the spherical rod ends would be just threaded on so they could rotate on the studs. Just grease them and thread them on to near bottomed out. They only need to be able to rotate 20-30 degrees. I have a homemade trailer that I have have used on my dirt bike (and bicycle) that uses a 3/8" SRE on a bolt. Have hauled 2-300 pounds with off road. I could make the arm going up to the control rod about any length that I want to make a short throw shifter.
Reply #24February 09, 2013, 06:22:15 pm
« Reply #24 on: February 09, 2013, 06:22:15 pm »
I worked on the gear shift bearings. I thought that I could do it with two nuts welded at right angles to each-other. The corresponding bolts  then could be welded to the gear shift lever and the other to a plate to bolt onto the floorboard.
Here is a short video of the action. Smooth and tight. I am using 7/16" bolts and nuts. A bit of grease on the threads would keep it tight for long time. Much better than the plastic ball.  I don't think I need the reverse lockout.
http://www.youtube.com/watch?v=yPJNPR4AS0w
« Last Edit: February 09, 2013, 07:12:00 pm by scrounger »
Reply #25February 09, 2013, 07:09:59 pm
« Reply #25 on: February 09, 2013, 07:09:59 pm »
can anyone view the video? It doesn't work and I have uploaded it twice.
Reply #26February 09, 2013, 07:31:04 pm
« Reply #26 on: February 09, 2013, 07:31:04 pm »
I could. I didn't listen to it, but I viewed it.
Reply #27February 09, 2013, 07:40:08 pm
« Reply #27 on: February 09, 2013, 07:40:08 pm »
Am on a cell phone internet. Perhaps our Amish neighbors are firing up theirs.
