Author Topic: Fuel Line routing?  (Read 6500 times)
October 15, 2012, 04:51:32 am
stewardc
Fuel Line routing?
« on: October 15, 2012, 04:51:32 am »
Is there a "proper" way to route the small return lines that go from injector to injector. I'm replacing mine with silicon lines and want to do it right.
Any pics would be nice.
Reply #1October 15, 2012, 08:31:40 am
stewardc
Re: Fuel Line routing?
« Reply #1 on: October 15, 2012, 08:31:40 am »
Anyone ???? ???
Reply #2October 15, 2012, 09:11:12 am
92EcoDiesel Jetta
« Reply #2 on: October 15, 2012, 09:11:12 am »
Daisy chain them (in series) with a cap on the last injector.
Reply #3October 15, 2012, 11:57:30 am
stewardc
« Reply #3 on: October 15, 2012, 11:57:30 am »
Oh. I know that, but how do you guys route them through all the junk that's there.....or does it even matter ?
Reply #4October 15, 2012, 02:39:36 pm
« Reply #4 on: October 15, 2012, 02:39:36 pm »
I make them all long enough to cut down on the side of the road at least once.
Reply #5October 15, 2012, 04:21:18 pm
TurboJ
  • 661
« Reply #5 on: October 15, 2012, 04:21:18 pm »
...and if you want to make sure there's the least possibility of leakage, I suggest twin return lines; i.e. from both ends of the injector bank.
Then just fit a Y-connector between them and the return port on the pump.
Jetta II 1.6 TD 'Project 200'
Reply #6October 15, 2012, 05:43:46 pm
stewardc
« Reply #6 on: October 15, 2012, 05:43:46 pm »
Wow, I never thought of that. I think I'll try it.
Reply #7October 15, 2012, 07:29:41 pm
« Reply #7 on: October 15, 2012, 07:29:41 pm »
I too like that idea!
Reply #8October 15, 2012, 07:40:50 pm
« Reply #8 on: October 15, 2012, 07:40:50 pm »
I like to crimp my return line and launch the little  cap into orbit though...
Reply #9October 15, 2012, 08:12:23 pm
« Reply #9 on: October 15, 2012, 08:12:23 pm »
I lost several caps to an overpressure issue when I went to WVO.  Seems I had the valves wired backwards and when I expected the fuel to flow during purge switch location I would send my plug a flying someplace.  Oil would cascade all over the front of the engine and I slightly tempted to use a bad word.  Once I put a meter on the setup it was a simple switch of colored plugs to the stock black end and problem solved.
I like the duel sided idea as well.  Why not?  Might be useful to have an alternative back route.  Escape route?
DAS
Reply #10October 16, 2012, 05:00:11 am
Gizmoman
  • 1301
« Reply #10 on: October 16, 2012, 05:00:11 am »
Sounds pretty slick - any photos of that set-up? Maybe it's too early in the morning, but I'm not getting a clear picture of how that works ;D
Reply #11October 16, 2012, 06:59:23 am
TurboJ
  • 661
« Reply #11 on: October 16, 2012, 06:59:23 am »
No picture, but the idea is that you have a return hose (back to pump) from both ends of the injector bank.
From injectors #1 and #4 make the "outmost" line go back to the pump, instead of just the one from the injector #4.
Y-connect them together for the return to the pump housing, or fit a twin banjo.
It works.
Reply #12October 16, 2012, 07:11:02 am
« Reply #12 on: October 16, 2012, 07:11:02 am »
Not sure how any additional lines/fittings could reduce the potential for leaking.
Reply #13October 16, 2012, 07:16:41 am
TurboJ
  • 661
« Reply #13 on: October 16, 2012, 07:16:41 am »
By easing off the pressure that builds onto the plugged return connector on the #1 injector, that's how.
This setup will reduce the pressure peaks on the injectors' return line system, especially at and near the #1 injector.
Up until, of course, your total fuel return flow exceeds the capacity of the lines altogether. Which can happen on a high-performance pump.
Reply #14October 16, 2012, 07:56:16 am
92EcoDiesel Jetta
« Reply #14 on: October 16, 2012, 07:56:16 am »
Do these pressure peaks on the injector return lines do any harm or affect running of the engine? It's just excess fuel that is not injected which has to go back to the tank. Why add another connection which is one more potential leak point? Another banjo? Are you kidding?
