Author Topic: Injection pump problems.  (Read 3722 times)
Reply #15September 11, 2012, 02:15:16 pm
Re: Injection pump problems.
« Reply #15 on: September 11, 2012, 02:15:16 pm »
That could make a difference. Any reason for doing that, like did you brake yours? If going another spline or as far as you can go with the splines won't do it. I would swap it back to the other one.
Reply #16September 11, 2012, 02:19:40 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Injection pump problems.
« Reply #16 on: September 11, 2012, 02:19:40 pm »
No mine is fine I just couldn't get it to start so winding the screw in was easier than adjusting the splines.
Sent from my DROID X2
Reply #17September 11, 2012, 09:07:14 pm
ToddA1
  • 434
« Reply #17 on: September 11, 2012, 09:07:14 pm »
There's a part (the camplate?) in the pump that can be installed 180° out.  It'd give the same effect of installing the pump with the pulley 180° out.  hard start, low power, etc..
Instead of pulling the pump apart, rotate the pulley 180° when at TDC. It's worth a shot.
-Todd
Reply #18September 11, 2012, 09:50:35 pm
« Reply #18 on: September 11, 2012, 09:50:35 pm »
Libby suggested removing the lines, key on and rotate the engine watching when fuel spills out #1 port.  Works great, and is more than accurate enough to tell which side of 180 you are at.
