Author Topic: No fuel, bad pump?  (Read 10121 times)
Reply #15February 22, 2006, 08:13:33 am
tadleyjane
  • 20
lacking fuel supply
« Reply #15 on: February 22, 2006, 08:13:33 am »
i drove my 81 diesel caddy 6000 miles after a complete rebuild-it ran great the whole the whole time. It had sat for 4 years prior to purchase. Then all of a sudden it started hard and ran poor after full throttle acceleration.  I changed the fuel filter and it helped for 50! miles.  Turns out the in-tank strainer (very fine mesh filter) had been coated in varnish.  i pulled the tank, cleaned the strainer with carb cleaner- replaced and it runs great.  good luck.
Reply #16February 23, 2006, 07:44:55 am
A Guy
No fuel, bad pump?
« Reply #16 on: February 23, 2006, 07:44:55 am »
I just saw this post.  I had the same problem last week and it turned out to be the 12v conection at the top of the pump.  I have a 1.6n/a 1991 golf.  It started fine once I cleaned it up.   Then changed the wire as it was cracked in a few places.
Good luck.
out.
Reply #17February 23, 2006, 03:18:28 pm
mainer
  • 126
No fuel, bad pump?
« Reply #17 on: February 23, 2006, 03:18:28 pm »
Quote from: "1slowvw"
Ok seems that my fuel shut down silenoid was the problem its not getting power at all so im gonna run some new lines tonight i assume its just a break in there somewhere.
Thanks for all you guys help im kinda new at this whole car thing.
1slowVW
nice job. For now u can just run a jumper cable to it, with a switch in the car, from the battery. or you could pull the spring and plunger and use the manual shut off.
Coop
_________________
recession history united states
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
