Author Topic: Auto transmission into 91 jetta na  (Read 6833 times)
Reply #15August 14, 2012, 09:08:11 am
Re: Auto transmission into 91 jetta na
« Reply #15 on: August 14, 2012, 09:08:11 am »
Our 010 is still going strong with 300k kms on it.. Behind the powerhouse of a RV 1.8 no less.
I would love to put an auto on a a diesel.. Spool the turbo against the brakes, ohh yeah. The 010 3spd might do alright for an IDI race car with a bigger than T3 turbo where you wanted to be 3000+ all the time.
Reply #16August 14, 2012, 10:09:25 am
« Reply #16 on: August 14, 2012, 10:09:25 am »
The vanagons and rabbit trans were basically the same, even Audi used them,  I think Audi even had a 4 speed version.  I had an na auto rabbit I loved it, it didn't seem down on power to me at all and consistently got 40mpg.  I quite miss it actually
what transmission was it? it prob wouldn't work in my mk2 though cuz the mounts are different eh?
Thyre all 010 but yes a vanagons trans only works for vanagons a golf/jetta for golf/ jetTas.  They are internally the same but have different things in different places
Reply #17August 14, 2012, 11:40:54 am
« Reply #17 on: August 14, 2012, 11:40:54 am »
the Vanagon, and audis used the same auto trans
you can un bolt the TRANSMISSION from the final drive assembly, and bolt it to a transverse final drive..
bam, instant tough rabbit/golf/jetta trans..
the audi and vanagon used 5 clutches in each pack, rather than the 3 of the rabbit style trans..
BTW.. diesel auto starters are RARE AS HELL.. they are not being produced, and barely remanufactured, because all of them are dead, and were not common to begin with..
« Last Edit: August 14, 2012, 11:57:14 am by R.O.R-2.0 »
Reply #18August 14, 2012, 11:49:28 am
« Reply #18 on: August 14, 2012, 11:49:28 am »
Hmm I thought the cases were actually different, but I have only ever seen them in golfs and jettas,  that's pretty sweet
Reply #19August 14, 2012, 12:09:51 pm
« Reply #19 on: August 14, 2012, 12:09:51 pm »
sux on the starter... lots more kubvans vs mk1...
the issue with the old auto besides gear ratio.... the seal will fail between the 2 halves and fill the final drive with atf.... then blow the diff apart... but hell check the gear oil 1x a year.. when its overfilled drill drain.. add plug... change it and atf.. add some jb (justice brothers) tranny conditoner to it... refill... check gear oil on all next oil changes... when it gets to point of too much oil... drain final drive.. refill.. only holds 1qt.. and keep eye on it... get another 100k easy..
Reply #20August 14, 2012, 06:07:35 pm
CrazyAndy
  • 739
« Reply #20 on: August 14, 2012, 06:07:35 pm »
So the FDs on 010s only had fill plugs and no drains?  That's pretty stupid.  But I'm with CRS on this one, just mod it before you put it into the car for ease of work.  Use a Chrysler oil drain plug on account of them having integrated rubber washers on the plug head as well as a mildly magnetized tip.  Do the auto trans diff cases have a flat spot where the drain would be on a manual?
Reply #21August 14, 2012, 06:34:32 pm
« Reply #21 on: August 14, 2012, 06:34:32 pm »
There is a fluid for the 010s that is compatible with the tranny and diff side just incase the seal does leak.
I'm pretty sure there is a drain on it, it's been a while since I had mine apart.
No matter what tranny you go with, if it's not a diesel auto, you will HAVE TO shift into neutral anytime you are at a stop. VW claims that the "E" on the diesel auto is so that it can coast when you take your foot off the gas and save fuel. If that was true the gassers would have it as well. It's purpose is so that at a stop the tranny automatically shifts into neutral so your car doesn't rattle apart.
That said, drop in a 010 from a gasser, it's a pretty easy swap and with the proper adjustments you'll be happy... or she will be anyways. You need both throttle cables (pedal to tranny, tranny to pump), and the auto pump bracket as they are unique to the auto diesel.
Reply #22August 14, 2012, 08:52:47 pm
« Reply #22 on: August 14, 2012, 08:52:47 pm »
correct no drain.. on either auto or fd..
auto drill pan at the spepped corner, weld thin 8mm nut inside... use copper washer and 8mm bolt..
fd.. ive always used a pipe plug... thing close to 10x1.. cannot think its american size.. but oil filter housings on pre 82 have them... taper fit for seal.. way before the allen plug and gasket they went too.. 4 sided square head.. why... not a flat spot on the casting for gasket.. but a usa style ntp taper fit pipe plug = tits perfect..
Reply #23August 14, 2012, 10:00:29 pm
« Reply #23 on: August 14, 2012, 10:00:29 pm »
I just picked up a 2002 Jetta with the O1M auto.  Reverse gear just disappeared.  That was the original trans and lasted to 238,000 miles.  Most of them had trouble or failed by 150-180,000 miles.  While the manuals basically go forever, 150,000 miles seems reasonable to me.  My wife also doesn't like to drive cars with manual transmissions and it's certainly not worth it to me to have her at all stressed out when driving.  While I prefer manual transmissions for the added control, better performance and increased fuel economy, she puts up with me and my quirks and maintaining an automatic for her as her daily driver is the least I can do.  The thought of choosing/ditching a significant other based on what transmission they want to drive seems incredibly shallow to me.
Not exactly the same, but interchangeable.  The Audi trans is more robust and commonly used as an upgrade in vanagonland.
« Last Edit: August 15, 2012, 07:56:58 am by libbydiesel »
Reply #24August 15, 2012, 01:11:40 pm
« Reply #24 on: August 15, 2012, 01:11:40 pm »
hmm, did not know that.. i always thought they had the same trans, but with the carrier/ring gear flipped around in the final drive..
thanks for the piece of info..
Reply #25August 15, 2012, 02:05:12 pm
« Reply #25 on: August 15, 2012, 02:05:12 pm »
I could look up the difference, but if memory serves, the audi unit has more splines on the planetary ring gear and an extra planetary gear (4 instead of 3) on each of the sets and so is stronger.  It may just be the Audi 5000 turbo ones that are stronger.  Anyway, the parts interchange for an even more robust unit.
Reply #26August 15, 2012, 02:07:33 pm
« Reply #26 on: August 15, 2012, 02:07:33 pm »
well, my audi trans is indeed a 5k TD unit, so its the tough one, with E mode..
BTW, my audi never needed to be in E or N when stopped.. it was worn far enough out that it wouldnt vibrate a whole lot at idle in gear
 :P
