Author Topic: WTB: Turbo Oil Lines!!!  (Read 5116 times)
July 26, 2012, 04:34:45 pm
Newschooldiesel
  • 14
« on: July 26, 2012, 04:34:45 pm »
In need of turbo oil feed and return lines. HMU if you have some!
1984 Rabbit - 1.6l Turbo equipped in the makins...
Reply #1July 26, 2012, 07:33:32 pm
Re: WTB: Turbo Oil Lines!!!
« Reply #1 on: July 26, 2012, 07:33:32 pm »
What engine? What turbo?
Reply #2July 27, 2012, 09:36:52 am
« Reply #2 on: July 27, 2012, 09:36:52 am »
just build some yo!
i told you i would help..
K03 turbo never came stock on the 1.6..
i believe the 1.9 was a block feed/drain, where as the 1.6 is a flange feed/pan drain..
Reply #3July 27, 2012, 11:00:48 am
damac
  • 531
« Reply #3 on: July 27, 2012, 11:00:48 am »
just build some yo!
every darn 1.6 td engine i have come across has a messed up oil return hose that is screwed up and seeping, i hate it so much.  i have to deal with this myself on multiple cars in the next couple months but have no clue what kind of shop to go to or  how to go about the repair.
1985 turbo diesel jetta
Reply #4July 27, 2012, 01:40:12 pm
« Reply #4 on: July 27, 2012, 01:40:12 pm »
just build some yo!
slide a piece of pink heater hose/oil hose over it, and clamp it tight..
you have to remove the ferrule, and the big nut from the end of the line to do it tho..
or else slit the crimps, and install a new section of line where the braided stainless teflon oil line once was..
matt is going to be using a K03 turbo on his 1.5D tho..
the K03 return line will NEVER bolt up to the 1.6, because it screws to the block, and the 1.5 has no provisions, neither does the 1.6..
(you can get KKK specific "universal" feed/return lines off ebay)
« Last Edit: July 27, 2012, 05:52:10 pm by R.O.R-2.0 »
Reply #5July 27, 2012, 03:32:01 pm
1.9aaz
« Reply #5 on: July 27, 2012, 03:32:01 pm »
I have a brand new like for a 1.6TD I believe I will confirm tonight
Reply #6July 27, 2012, 04:22:57 pm
« Reply #6 on: July 27, 2012, 04:22:57 pm »
the K03 feed line will NEVER bolt up to the 1.6, because it screws to the block, and the 1.5 has no provisions, neither does the 1.6..
K03 takes its oil feed from the oil filter housing.
Reply #7July 27, 2012, 05:52:35 pm
« Reply #7 on: July 27, 2012, 05:52:35 pm »
thanks for pointing out my mistake, i have since corrected it.
Reply #8July 29, 2012, 10:56:29 am
« Reply #8 on: July 29, 2012, 10:56:29 am »
Anytime.
Reply #9July 31, 2012, 11:48:19 am
Newschooldiesel
  • 14
« Reply #9 on: July 31, 2012, 11:48:19 am »
so do you have the oil lines?
Reply #10July 31, 2012, 01:52:50 pm
« Reply #10 on: July 31, 2012, 01:52:50 pm »
MK1 and MK2 1.6 drain lines are different btw.
