Author Topic: AAZ and 92 Golf 1.8L (8v) flywheel  (Read 12274 times)
Reply #15August 28, 2012, 06:57:34 am
SR Heer
  • 199
Re: AAZ and 92 Golf 1.8L (8v) flywheel
« Reply #15 on: August 28, 2012, 06:57:34 am »
How much did your 210mm flywheel from 92 Golf weigh? I am thinking of doing the same with a 1.6TD going into Caddy but have heard that with diesel motors need at least 11lbs and up to work well - is there a minumum of sorts weight that a flywheel should be for using with diesel motors?
Was there a noticable difference in how the motor performed and do you consider this a practicul worthwhile conversion?
Reply #16August 30, 2012, 08:11:54 am
bbob203
  • 1789
« Reply #16 on: August 30, 2012, 08:11:54 am »
wrong thread :-X
« Last Edit: August 30, 2012, 10:31:04 am by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #17August 30, 2012, 08:08:43 pm
« Reply #17 on: August 30, 2012, 08:08:43 pm »
I don't think any lighter than a stock 210mm flywheel is needed. 210mm is quite a bit lighter than the stock 200mm for that extra 5mm all the way around of extra machined surface. I am using a completely stock 210mm gasser setup with stock Sachs clutch kit on my AHU M-TDI right now and it revs up fantastically quick!
Reply #18August 30, 2012, 10:41:15 pm
erice1984
  • 263
« Reply #18 on: August 30, 2012, 10:41:15 pm »
I don't have a base to compare the 210mm flywheel to. I can say that the AAZ responds well to the 210mm flywheel without any adverse effects that I can tell.  I would stay away from LIGHTENED flywheels especially.
1980 Rabbit 1.9TD
Reply #19August 31, 2012, 11:36:10 am
« Reply #19 on: August 31, 2012, 11:36:10 am »
diesels come with heavy wheels factory. much more heavy than the gassers. (210mm atleast)
the diesel FW is like 17 pounds, while the gasser unit is 12.. i weighed them once upon a time.. fairly large difference.
so, to a diesel, even a stock gasser wheel is light..
and a lightened flywheel is just too light.. makes them vibrate much worse at idle as well..
heavy wheels are there to help smooth out the rough nature of these engines..
