Author Topic: crossing the border with an AAZ  (Read 5001 times)
July 03, 2012, 03:46:30 pm
kd4yor
  • 37
« on: July 03, 2012, 03:46:30 pm »
Does the US have an issue bring in an AAZ in the bed of a pick up? anyone had an engine seized for non EPA compliance? is this even an issue?
« Last Edit: July 04, 2012, 05:20:26 pm by kd4yor »
Reply #1July 03, 2012, 04:02:00 pm
Re: crossing the border with an AAZ
« Reply #1 on: July 03, 2012, 04:02:00 pm »
get a receipt for a VW INDUSTRIAL ENGINE...
Reply #2July 04, 2012, 08:19:39 am
« Reply #2 on: July 04, 2012, 08:19:39 am »
If you can take the head off the engine it's now "used car parts" and that should make it easier. I've sold long blocks (no accessories) to americans before and just wrote on the receipt the VIN that the engine came from and that it was parts sold for xxx dollars.
Reply #3July 07, 2012, 04:21:11 am
catlin_cava
  • 1954
« Reply #3 on: July 07, 2012, 04:21:11 am »
Pull the head off, and rods and pistons out and name it a VW 1.9TD industrial and it's good to go:P
Its sitting at work sill in the car staring at us :P
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #4July 19, 2012, 08:56:44 am
fdnyguy
  • 499
« Reply #4 on: July 19, 2012, 08:56:44 am »
Sorry to hijack a thread, but if I buy a car on that side as planned, should not be a problem???
Thanks in advance.
Stay safe, stay well. Jimmy.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #5July 19, 2012, 10:05:17 am
« Reply #5 on: July 19, 2012, 10:05:17 am »
I know coming from the states if the car is older than 15 years it is easy. They still want some form faxed to them 48 hours in advance though
Reply #6July 19, 2012, 10:56:55 am
rs899
  • 647
« Reply #6 on: July 19, 2012, 10:56:55 am »
Fsnyguy-
I don't think it's going to be that easy.  I think you will have problems getting anything newer than 25 years old over.  Even then, don't rely on what anyone here tells you.  Go check out the customs regs- they are out there on the internet.
Reply #7July 19, 2012, 03:57:44 pm
fdnyguy
  • 499
« Reply #7 on: July 19, 2012, 03:57:44 pm »
Fsnyguy-
Will do, thanks for the heads up. Problem is, not too many diesels on our side of the border for the prices I've seen. While my mechanical skills basically suck, I do have some eyesight on severe rust, which between the Mk3's reputation, along with Canadian winters will obviously knock out any car with these issues.The pics I have seen the cars look good, but we know we can't go by photos. As for the mechanical, Tyler, as usual stepped up and I trust his expertise, along with others (should I hear from them) whose posts I  probably have read. I'll also check NYS DMV as well in the am when I leave work. Thanks again.
Stay sae, stay well. Jimmy.
« Last Edit: July 19, 2012, 06:04:07 pm by fdnyguy »
Reply #8July 19, 2012, 05:00:58 pm
rs899
  • 647
« Reply #8 on: July 19, 2012, 05:00:58 pm »
Reply #9July 19, 2012, 06:50:55 pm
fdnyguy
  • 499
« Reply #9 on: July 19, 2012, 06:50:55 pm »
http://www.epa.gov/oms/imports/canadian.htm
here's more "help"
Now I owe YOU a beer... lol. Seems the 98's good to go if I like it. Thanks for the research work. Now I just need the time off to go look.
Reply #10July 20, 2012, 03:47:43 am
rs899
  • 647
« Reply #10 on: July 20, 2012, 03:47:43 am »
Appears to be doable, but I think you still need to dig in to it more..
http://www.epa.gov/otaq/imports/forms-resources.htm
I would get the guide listed here and call the phone number at the bottom of the page before I handed over any cash.  And check with your state tag bureau.  You still may have some customs/duty issues- should plan for that too.
Seems like a recipie for disaster if you don't have all your ducks in a row.  The rewards may be worth it, though as we have really been starved for usable diesels south of the border since the mid 80s.
« Last Edit: July 20, 2012, 04:07:42 am by rs899 »
Reply #11July 20, 2012, 05:20:29 am
« Reply #11 on: July 20, 2012, 05:20:29 am »
I had a guy in canada come over with 4 blocks with no heads. They didn't even ask him a question. The blocks had IP's, water pumps, oil pans full of oil, and they didn't even look. I would say if they are broken down that far you should be good. I bet if you even had the heads you could still come across. Still, asking questions would be the best bet.
Reply #12July 20, 2012, 08:54:10 am
rs899
  • 647
« Reply #12 on: July 20, 2012, 08:54:10 am »
he's asking about a running car, but tagged it to a parts thread.  I think a car is a whole different animal than parts.
Reply #13July 20, 2012, 10:22:31 am
Dakotakid
  • 1240
« Reply #13 on: July 20, 2012, 10:22:31 am »
According to what I read in this info provided:  just make sure the actual BUILD DATE of the car was Jan. 1, 98. Instead of it being a late '97 roll-off-assembly line date. They clearly state (as I see it) and use the date of Jan. 1st.
Friggin' fine print.
Reply #14July 23, 2012, 07:22:13 am
fdnyguy
  • 499
« Reply #14 on: July 23, 2012, 07:22:13 am »
Yes, I did. My apologies for the hijacking. But went to NYS DMV and she gave me the 'normal' forms. However, as someone posted about 'ducks in a row', I will check Federal sites to play it safe.
Again, thanks for the info and apologies for the hijack.
