Author Topic: what can I use?  (Read 4092 times)
February 15, 2006, 11:31:59 am
chrissev
  • 694
what can I use?
« on: February 15, 2006, 11:31:59 am »
Need some ideas on substitutions for the following items:
1.9 IDI valve cover
1.9 IDI intake manifold
also does anyone have a 155 bar turbo injector they would want to sell to me?  Have three, need one more.
88 Jetta TD....sold for $1000, bought an 06 Cobalt, clearing out the diesel jetta stuff now
Reply #1February 15, 2006, 11:35:53 am
BlackTieTD
  • 1512
what can I use?
« Reply #1 on: February 15, 2006, 11:35:53 am »
this is totally a hunch but i think other older 8v stuff will bolt up...might try parts from a 1.6TD to see if the bolt holes match..... i think they do.
Reply #2February 15, 2006, 11:44:40 am
zyewdall
  • 393
what can I use?
« Reply #2 on: February 15, 2006, 11:44:40 am »
The 8v 1.8 gasser that I took out of my car appeared to have the same valve cover as the 1.6IDI.  And the exhaust and intake manifolds bolted right up (of course the intake was different so I used the diesel manifold)
Hope this helps somewhat.
'84 Mitsubishi 4x4 2.3L turbo biodiesel pickup
'91 VW Rabbit GTI with 1.6 biodiesel transplant
'81 Toyota longbed 2wd 2.2NA biodiesel pickup (for sale)
'89 Subaru 4x4 touring wagon
 '82 subaru 4x4 TDI wagon -- project on hold
1976 Ford Sasquatch pickup
Reply #3February 15, 2006, 03:31:11 pm
chrissev
  • 694
what can I use?
« Reply #3 on: February 15, 2006, 03:31:11 pm »
thanks for the replies so far.  the 1.9 IDI cylinder head has an interesting valve cover that I haven't seen anywhere else.  There are three or four raised threaded rods that extend out of the endcaps and go through the top of the valve cover.  Nuts are then threaded down onto these rods to hold the valve cover in place.  The 1.6 IDI head is different, the valve cover is bolted down with 10mm bolts that go into the cylinder head, I believe there are around 10 of them.  As far as the intake manifolds go, I am looking for one with "D" shaped ports as the 1.9 IDI head has these.
Reply #4February 15, 2006, 03:33:03 pm
chrissev
  • 694
what can I use?
« Reply #4 on: February 15, 2006, 03:33:03 pm »
Quote from: "BlackTieTD"
the bolt holes do match....but the ports on the 1.6TD intake are "O" shaped, and those on the 1.9 head are "D" shaped.   :cry:
Reply #5February 15, 2006, 04:05:44 pm
DieselMonkey
  • 124
what can I use?
« Reply #5 on: February 15, 2006, 04:05:44 pm »
I dont think you'll find any other valve cover for a 1.9 IDI. Only other choice would be to have one CNC milled.
Matt
Reply #6February 15, 2006, 05:21:38 pm
chrissev
  • 694
what can I use?
« Reply #6 on: February 15, 2006, 05:21:38 pm »
Quote from: "DieselMonkey"
Matt
might have to buy one new then.  there don't seem to be any 1.9 IDIs in the scrap yards around here.  they are rare cars it seems.
Reply #7February 16, 2006, 08:20:43 am
BlackTieTD
  • 1512
what can I use?
« Reply #7 on: February 16, 2006, 08:20:43 am »
you can find one used. try posting in the classifieds here or on the vhortex.
