Author Topic: 2.3 CIS into 1.6TD conversion  (Read 9475 times)
Reply #15June 14, 2012, 03:12:57 pm
Re: 2.3 CIS into 1.6TD conversion
« Reply #15 on: June 14, 2012, 03:12:57 pm »
dude, i got 2 words for you...
ZOOM OUT!!
that shows us nothing of the actual engine bay, just parts of it..
and please tell me you GUTTED the CIS fuel distributor?
Reply #16June 15, 2012, 05:18:38 am
Katada
  • 8
« Reply #16 on: June 15, 2012, 05:18:38 am »
Hope this picture helps.
Engine bay:
I de-attached the CIS fuel distributor from the air flow sensor housing, kept the sensor connected and functional to
eliminate any chance for limp mode.
Reply #17June 15, 2012, 06:39:42 am
« Reply #17 on: June 15, 2012, 06:39:42 am »
You could find a broken timing belt cover and cut out parts that your RPM signal is sticking out. That way at least you would have a cover over the rest of it.
Also I thought it wasn't an eco pump as I thought they had the fast idle and I don't see that on yours.
That CIS fuel distributor is going to be a restriction I bet.
Reply #18June 15, 2012, 10:47:36 am
« Reply #18 on: June 15, 2012, 10:47:36 am »
That CIS fuel distributor is going to be a GUARANTEED restriction.
FTFY <3
Reply #19June 15, 2012, 08:21:36 pm
Dakotakid
  • 1240
« Reply #19 on: June 15, 2012, 08:21:36 pm »
This is taking us places we have not dared to venture before.
« Last Edit: June 15, 2012, 08:24:01 pm by Dakotakid »
Reply #20June 15, 2012, 09:41:56 pm
« Reply #20 on: June 15, 2012, 09:41:56 pm »
Just dumping the crank vent in the engine compartment?
Reply #21June 15, 2012, 11:24:02 pm
Katada
  • 8
« Reply #21 on: June 15, 2012, 11:24:02 pm »
The car is under long term test, a lot of work still to do, crank vent included.
