Author Topic: New Td and not starting.  (Read 11794 times)
Reply #45May 04, 2012, 06:28:05 pm
One_punchmachinegun
  • 261
Re: New Td and not starting.
« Reply #45 on: May 04, 2012, 06:28:05 pm »
will the lda off my TD IP fit on to my N/A IP with a altitude compensator? Top swap?
“If anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #46May 05, 2012, 11:34:01 am
« Reply #46 on: May 05, 2012, 11:34:01 am »
theres more to it than a top swap.
n/a pump has a fuel limiter pin in the side of the case that needs to be removed, or pushed out of the way.. otherwise you get no gains.
if you just do the pump top swap, then you gain nothing.. the limiter pin is still in place, so just before the LDA wants to engage, the throttle arm hits the limiter pin, and goes no further.. the TD pump DOES NOT have this pin..
but, had you searched a little, you would have already known this, and how to correct it, because this EXACT topic has been gone over HUNDREDS of times..
Reply #47May 05, 2012, 01:15:24 pm
« Reply #47 on: May 05, 2012, 01:15:24 pm »
I don't think the limiting pin is present on the altitude compensating pump, which is what he's asking about.  It should be a direct swap.
Reply #48May 18, 2012, 03:19:28 pm
One_punchmachinegun
  • 261
« Reply #48 on: May 18, 2012, 03:19:28 pm »
just want to update this, CAR HAS STARTED! IP timing needs a little adjustment. But it starts. Thank you all for your input. Your guys are da'best. ;D
