Author Topic: k24/t3 on AAZ concise and simple!  (Read 18210 times)
Reply #15April 29, 2012, 01:10:34 pm
Re: k24/t3 on AAZ concise and simple!
« Reply #15 on: April 29, 2012, 01:10:34 pm »
You might also have to grind a bit away from the intake manifold to make it all fit.
You can modify your current downpipe by cutting off a bit of the bottom of the flange and drilling two holes. A custom mandrel bent one would be better though.
Also, you will need to change the intake boot from the filter to the turbo. You might need to go custom here.
Reply #16April 29, 2012, 04:58:45 pm
CrazyAndy
  • 739
« Reply #16 on: April 29, 2012, 04:58:45 pm »
Why not just pick up a good used k24or t3 intake boot?
Reply #17May 09, 2012, 10:50:52 pm
tdotdub
  • 52
« Reply #17 on: May 09, 2012, 10:50:52 pm »
“THEZORN” so since the ports are different do I just continue using the AAZ intake manifold?
I have a pd150 manifold with egr in a box but want to use that on my tdi, im pretty sure the aaz will never be as fast as the tdi,so I rather use it there…..
I bought a nice T3 turbo with the 1.6td intake and exhaust as well as oil line from 1.6td.
So far I gather that I can either change the oil pan to a 1.6td one and block off the aaz oil return (http://www.brickwerks.co.uk/index.php?page=shop.product_details&category_id=59&flypage=flypage.tpl&product_id=333&vmcchk=1&option=com_virtuemart&Itemid=3) BUT will I loose any oil capacity? or take it to a hydraulic shop and have them make a custom line in between. Anyone know roughly how much longer it has to be? Or do I have to mock it up first and than take it to them?
this looks good, but having doubts having it shipped from the UK. http://www.brickwerks.co.uk/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=332&category_id=59&vmcchk=1&option=com_virtuemart&Itemid=3
I do plan on intercooling it once I fix some other issues first,I want to be pushing 24 psi reliably,plus the aaz is not egt friendly I read.
I really like what “chrisg” did, chopping off and welding it on seems fairly straight forward! might try that.
I didn’t think about the intake boot, but ur right,its bigger on the turbo side,ill get one…..i put a cone air filter on the one I have now, holly is it LOUD! As far as exhaust going to go with a custom mandrel bent one, 2.5”.
My clutch is slipping at 18 psi on the k14 now, but hopefully the slower spool of the t3 will help with that. Its weird, I don’t really see others sliping their clutches with good power, is it just my clutch or you guys upgrade to something? Should I replace with a new oem clutch and assume it will hold with a fresh pressure plate….
This is in a mk3 cabrio btw.
87 Audi 5000S Quattro Turbo Diesel (the car I want to light on fire everyday)
99 Beetle TDI (the beater)
99.5 Cabrio  (the innocent one)
Reply #18May 10, 2012, 08:42:51 am
« Reply #18 on: May 10, 2012, 08:42:51 am »
i think aaz and tdi should perform quite similarly with similar mods, the thing with the tdi is that it comes factory with bigger pump head and intercooler, along with it all being electronically controlled.  i think either engine will benefit from a better intake.  but other wise yes keep your current intake manifold.  on my 1.6 with k24 at 25psi the clutch started slipping, i think any turbo diesel with increased performance suffers from this, the stock clutches are made for 70hp at the most...
Reply #19May 10, 2012, 12:32:28 pm
« Reply #19 on: May 10, 2012, 12:32:28 pm »
The 1.9 blocks are taller than the 1.6 blocks, so the 1.6 oil return line might not be long enough to reach the 1.6 pan on a 1.9.
Reply #20May 10, 2012, 03:42:45 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #20 on: May 10, 2012, 03:42:45 pm »
Bummer.... guess I should look into a better clutch for when I get around to the 'power' build I'm planning. Any recommendations on an upgraded clutch setup?
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #21May 12, 2012, 06:44:58 pm
chrisg
  • 72
« Reply #21 on: May 12, 2012, 06:44:58 pm »
there is no need to change the intake manifold.... just the little elbow on the top
Reply #22May 13, 2012, 07:56:45 am
nathan_b
  • 361
« Reply #22 on: May 13, 2012, 07:56:45 am »
the turbo coldside physically hits a casting mark on the aaz intake manifold.
Reply #23May 13, 2012, 04:42:46 pm
chrisg
  • 72
« Reply #23 on: May 13, 2012, 04:42:46 pm »
oh ya, i just quickly fixed that with a small file and 5 minutes.
Reply #24April 07, 2013, 04:45:18 pm
jimbobpolo
  • 45
« Reply #24 on: April 07, 2013, 04:45:18 pm »
My polo with 1.9td and k24 turbo..
http://m.youtube.com/watch?v=cl0mvejiWaU
