Author Topic: 1981 Rabbit Pickup 1.6D Rebuilt Caddy  (Read 9091 times)
Reply #15April 25, 2012, 10:13:24 am
maxfax
  • 2126
Re: 1981 Rabbit Pickup 1.6D Rebuilt Caddy
« Reply #15 on: April 25, 2012, 10:13:24 am »
i dont understand why i have allot of oil in my radiator and hoses?
The little rubber o-ring in the gasket around the head bolt that the oil is fed though deteriorates.. SInce the oil pressure is rather high on these it will both push out of the engine externally and usually over towards the coolant ports as well.. You may not see any major flaws in the gasket when this happens..  Once again, check around the head bolt holes VERY closely for cracks... Even a hairline crack in the bolt hole where the oil s fed can make a soupy mess in the coolant...
I have an '81, and it has 12mm head bolts.  Late '81 had 12mm.  All '82 AFAIK had 12mm.  Only the early '81 1.6 and 1.5L engines had 11mm.
Matt, where was your car built?   I've seen about 3 82's with 11mm bolts, all from the Pennsylvania plant.. I figured they had some leftover '81 engines to get rid of.. Never though to look at the '81's with 12mm to see where they came from..
Reply #16May 05, 2012, 06:20:56 pm
slavik19
  • 59
« Reply #16 on: May 05, 2012, 06:20:56 pm »
so head gasket was a success!
truck runs and drives great now
so it seams
will see how much oil it eats.
antifreeze seems stable.
going to get some cleaner or raditor flush and get the oil out of the cooling system.
got a question
my glow plugs worked like i remember the light turning on and everthing
i disconected the wiring now it wont work.
i got the coolant temp and "oil light" wires hocked up the extra wire also to the coolant temp sensor
the front flang has 2 red wires i connected them, but what do the other ends connect to?
Reply #17May 10, 2012, 07:25:17 am
MattRabbit
  • 45
« Reply #17 on: May 10, 2012, 07:25:17 am »
My car was built in Pennsylvania as well.  We purchased it in May/81.  I was a youngin' at the time, but since the car has been in my family since new, I know it has the original engine.  I've replaced the head gasket/rings/rod bearings, and I had to purchase new 12mm head bolts.  Yep, it's definitely an '81, definitely 12mm.
'81 Rabbit Diesel
'01 Golf TDI
http://matt_lisa.home.sprynet.com/
Reply #18May 12, 2012, 12:25:21 pm
EcoTX
  • 113
My 1982 is 11mm block
« Reply #18 on: May 12, 2012, 12:25:21 pm »
I just picked up a 2/82 build date Rabbit with an 11mm block and hex (11mm) bolts in head.  It even has 1.6 D on the block too...
My chassis number indicates I missed getting a 12mm by about 1000 cars... :(
Reply #19June 27, 2012, 09:07:38 pm
sprstu
  • 99
« Reply #19 on: June 27, 2012, 09:07:38 pm »
I too have an '81 with 12mm head.
I buy 90% of my stuff from Autohausaz.com, great prices and free shipping on orders over $50, and who doesn't spend $50 on parts!?
Head Gasket, bolts, T-Belt and tensioner, water pump and then just run the crap out of it.
edit: totally just read the second page. Congrats on a running engine!
« Last Edit: June 27, 2012, 09:09:54 pm by sprstu »
Mk1 caddy TD, mk4 Golf Tdi
Reply #20July 03, 2012, 11:06:16 am
slavik19
  • 59
« Reply #20 on: July 03, 2012, 11:06:16 am »
yes autohauz is great!
spoke to soon. i have a a crack somewhere in my head when your run the engine for about 2 hours undersome pressure it leaks oil into the coolant.
i already purchased a running mk2 engine out of a 92 jetta NA
and a mk1 turbo diesel engine out of a quantum, to bad all the engine mounts are sideways..
will be atempting to install mk2 1.6d NA into the caddy
Reply #21July 03, 2012, 11:14:19 am
slavik19
  • 59
« Reply #21 on: July 03, 2012, 11:14:19 am »
picked both of them up.
one should be running
TD runs but leaks and throttle doesn't work
« Last Edit: July 03, 2012, 11:21:38 am by slavik19 »
Reply #22October 13, 2012, 06:45:49 pm
sprstu
  • 99
« Reply #22 on: October 13, 2012, 06:45:49 pm »
That came out of a Quantum? What turbo is hanging on the back side?
Reply #23October 14, 2012, 02:13:45 pm
vwroadkill
  • 137
« Reply #23 on: October 14, 2012, 02:13:45 pm »
hey I can help if ya need some... for parts I go to eurowise. talk to Phil Pinto..they are working on 3 vw trucks right now.. if ya need windows or some vw parts hit me up with a PM I live in gastonia and work at the airport.
Dan
new owner of an 81 caddy diesel yipeeeee..vw gti vr6 and well most of gm's trucks
