Author Topic: I replaced my camshaft seal and it still leaks  (Read 5518 times)
March 28, 2012, 01:53:53 pm
srgtlord
  • 797
« on: March 28, 2012, 01:53:53 pm »
Anyways why would this happen? WHat the heck did I do wrong? I followed the instructions in the Bentley.
« Last Edit: March 28, 2012, 05:49:38 pm by 8v-of-fury »
Reply #1March 28, 2012, 03:16:17 pm
Re: WTF I replaced my camshaft seal and it still leaks
« Reply #1 on: March 28, 2012, 03:16:17 pm »
if the camshaft were warped, it would never seal properly again. However how many warped cam ends has anyone seen? Timing belt too tight? Its possible
Reply #2March 28, 2012, 03:59:49 pm
dieselweasel
  • 312
« Reply #2 on: March 28, 2012, 03:59:49 pm »
Is there a groove in the camshaft sealing surface?  Is the seal in square?
Reply #3March 28, 2012, 04:02:05 pm
« Reply #3 on: March 28, 2012, 04:02:05 pm »
Is it leaking around the camshaft or around the cap?
Reply #4March 28, 2012, 04:23:37 pm
srgtlord
  • 797
« Reply #4 on: March 28, 2012, 04:23:37 pm »
Im not sure where exactly. It looks wet around the edge of the seal. Maybe it got distorted when I pushed it in. Ill know this weekend after I pull the belt for the 3rd time. Any advice for RTV sealers? lol
Reply #5March 28, 2012, 04:45:33 pm
« Reply #5 on: March 28, 2012, 04:45:33 pm »
I would almost bet it's really the vc gasket leaking.
Reply #6March 28, 2012, 04:49:55 pm
srgtlord
  • 797
« Reply #6 on: March 28, 2012, 04:49:55 pm »
Thats a possibility , but I upgraded to the rubber gasket....
Reply #7March 28, 2012, 04:55:22 pm
« Reply #7 on: March 28, 2012, 04:55:22 pm »
I did too and still have leaks. I think the whole problem is the garbage warpable stamped steel valve covers. It would be nice if the cast aluminum ones were cheaper and easier to find.
Reply #8March 28, 2012, 05:48:16 pm
srgtlord
  • 797
« Reply #8 on: March 28, 2012, 05:48:16 pm »
How would I rule out the valve cover leaking? RTV? Non-Hardening Gasket sealer? Another valve cover?
Reply #9March 28, 2012, 10:39:24 pm
  • 2932
Re: I replaced my camshaft seal and it still leaks
« Reply #9 on: March 28, 2012, 10:39:24 pm »
It's like the cam starts to taper before the seal has room to seal.
 I'm not sure the outer dust seal even touches the cam.
 Did you grease the seal lips?
Reply #10March 29, 2012, 12:50:13 am
« Reply #10 on: March 29, 2012, 12:50:13 am »
The Bentley might have forgot to mention taking a ball pein and a wood block, and undimpling all the bolt holes in the VC.
