Author Topic: How much "PLAY" should be in the throttle shaft of an inection pump?  (Read 3278 times)
March 01, 2012, 05:49:08 pm
srgtlord
  • 797
Just as the post indicates, How much play is acceptable before the bushing needs to be replaced?
Reply #1March 01, 2012, 05:59:17 pm
410
  • 581
Re: How much "PLAY" should be in the throttle shaft of an inection pump?
« Reply #1 on: March 01, 2012, 05:59:17 pm »
Is it leaking fuel?  I normally change the bushing if it's leaking fuel and changing the o-ring doesn't fix the problem.  A little play is acceptable.  You can also check to make sure the nut holding the lever on is tight.
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles.  Sold!
Reply #2March 01, 2012, 07:51:55 pm
« Reply #2 on: March 01, 2012, 07:51:55 pm »
The pump did not leak from the throttle shaft when pulled. A new o-ring was installed on the throttle shaft, and it was a tight fit to get the throttle shaft back in to the lid of the pump.
