Author Topic: Wanted - 12mm 1.6 block w/ usable standard bore.  (Read 5572 times)
Reply #15March 04, 2012, 10:51:08 am
Jetmugg
  • 530
Re: Wanted - 12mm 1.6 block w/ usable standard bore.
« Reply #15 on: March 04, 2012, 10:51:08 am »
I am the LSR guy, but at this point, I'm still not sure whether a hydraulic or mechanical block would be the better choice.  I think it would probably work either way for me.  Some say that the mechanical setups can make more power for a given rpm, and may be able to spin more rpms without problems.  However, if I wanted to do a "Franken" setup, then the hydro would be an easier setup.
Do you have any good blocks, TheMan?
Steve.
