Author Topic: FS 1.6TD Pump/Injectors/Lines-----SOLD  (Read 7808 times)
Reply #15February 12, 2012, 12:24:20 pm
Re: FS 1.6TD Pump/Injectors/Lines
« Reply #15 on: February 12, 2012, 12:24:20 pm »
I said that wrong.  They should have noticeable radial play but axial play (thrust) should be virtually imperceptible.  I'll edit my original post.
Reply #16February 12, 2012, 04:16:14 pm
« Reply #16 on: February 12, 2012, 04:16:14 pm »
In-out=bad.  Side to side=good.
Reply #17February 12, 2012, 04:52:06 pm
« Reply #17 on: February 12, 2012, 04:52:06 pm »
after running my K24 today, i felt the clearances again, and the axial (thrust) clearance is tight, undetectable.. there is a TINY bit of radial clearance tho, just as should be..
Reply #18February 13, 2012, 07:27:25 pm
Dakotakid
  • 1240
« Reply #18 on: February 13, 2012, 07:27:25 pm »
One of the few times when getting the ol' "in-out" ain't a good thing............
Reply #19February 13, 2012, 07:31:30 pm
« Reply #19 on: February 13, 2012, 07:31:30 pm »
After reading this I ran down to the shop to check on the k03 on my AHU. After 430,000kms there is no.. In and Out play being  pushing the shaft parallel with the ground, and just a bit of up and down play.. the fins towards the compressor housing.
Reply #20February 16, 2012, 05:50:41 pm
« Reply #20 on: February 16, 2012, 05:50:41 pm »
Update your original thread title, you may get more interest :).
