Author Topic: Help With 94 Jetta AAZ Rebuild  (Read 19595 times)
Reply #30February 15, 2012, 01:58:10 pm
Re: Help With 94 Jetta AAZ Rebuild
« Reply #30 on: February 15, 2012, 01:58:10 pm »
It was/is stronger than the original part.  I can't help you with your fears.
Reply #31February 24, 2012, 08:48:46 am
TonyTDTruck
  • 110
« Reply #31 on: February 24, 2012, 08:48:46 am »
Hey R.O.R-2.0,
Libby is correct. The aluminum brace at that point is weaker. The new 3/8" bar runs down the mount making the whole mount stronger, not only the extended portion that was added.
Especially if the aluminum mount has corrosion like mine does.
I have a question regarding the pulleys for this AAZ. Here in the pictures you see my setup with an A/C. I'm removing the A/C compressor and now I find the pulley situation a bit different. Syncroincity has his AAZ with no A/C and I see in his build where his water pump has a different pulley. Does anybody have the p/n for this water pump pulley? And will I need anything else? My truck doesn't have P/S so I don't need that pulley.
Bentley shows this pulley as well.
Thanks for the help
Tony
How do you wash a pressure washer?
And did you know that the 14th floor in a
hotel is actually the 13th floor!
Reply #32February 24, 2012, 11:03:01 am
« Reply #32 on: February 24, 2012, 11:03:01 am »
way cool!! its a cutaway of the oval piston diesel that never made production!!!
