Author Topic: looks like the franken is getting parked for the winter.......  (Read 4662 times)
Reply #15December 16, 2011, 11:35:58 pm
monomer
  • 414
Re: looks like the franken is getting parked for the winter.......
« Reply #15 on: December 16, 2011, 11:35:58 pm »
I had thought about an intake grid heater.  Anyone tried this?
Dodge has ;)
www.michiganvw.org
Reply #16December 17, 2011, 01:32:15 am
nathan_b
  • 361
« Reply #16 on: December 17, 2011, 01:32:15 am »
my franken mk1 started -12f with stock glow plugs, no block heater. never failed to start in cold.
Reply #17December 17, 2011, 11:11:25 am
« Reply #17 on: December 17, 2011, 11:11:25 am »
You are running a Franken with a too thick head gasket, complaining about starting issues at 20F?!?  ::)
By the way, your turbo is surging up high so better make that wastegate do it's job before your turbo detonates.
If you read the original post I KNEW frankens arent the best starting wise.  I dont push my car to max boost much at all so the wastegate is staying blocked.
Im just wondering if it is worth the time/money to put a 1.6 1 notch in.  I generally plug my car in at home and at work so thats not the trouble.  Before I did the overhaul I had a tractor tank heater on the engine which worked real good but I had to open the reservoir for the coolant or it wouldnt pump.  I may just drive the old ford aspire to work for the winter.  Having my car plugged in all the time is a PITA, and since the franken setup the engine doesnt heat as good as the old stock head/block did.      I also dont relish the idea of driving my rust free car anymore in the winter salt.
it would get better mileage with a FUNCTIONING wastegate..
