Engine is finally IN!!
Pages:
Topic: Engine is finally IN!! (Read 6686 times)
Reply #15
December 20, 2011, 08:54:11 am
baldone
Re: New engine almost ready to go in...
Reply #15 on:
December 20, 2011, 08:54:11 am »
nice work!
Reply #16
December 21, 2011, 11:12:39 am
BigVWman
Reply #16 on:
December 21, 2011, 11:12:39 am »
Diesel porn at its finest!!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby, 87 gti, 01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #17
March 08, 2012, 05:46:22 pm
funkaholik
Reply #17 on:
March 08, 2012, 05:46:22 pm »
Update: Engine is done & ready to go in. Trans is rebuilt with Peloquin and .71 5th gear swap.
Spent Saturday morning degreasing & powerwashing the engine compartment. After much debate, I decided to scrap the non-working R12 A/C system. Finally sorted out the alternator bracketry necessary for a clean A/C delete. Engine and trans should be in this week.
Once the downpipe is back from ceramic coating, it gets bolted on and fired up!
Transmission:
No Face:
Erik Miller
1981 VW Caddy - 1.6TD
2005 Infiniti G35 - Vortech supercharged, drinking E85
1967 Mustang - 390 4 speed - for sunny days
1970 Datsun SPL311 Roadster - hibernating...
Reply #18
March 08, 2012, 07:26:28 pm
Reply #18 on:
March 08, 2012, 07:26:28 pm »
nice car.. i seem to notice alot more nice mk2 jettas on the forum lately..
Reply #19
March 09, 2012, 12:23:32 pm
funkaholik
Reply #19 on:
March 09, 2012, 12:23:32 pm »
By the way, has anyone else used the metal "polish" Calyx before? It goes on with a toothbrush and works into the metal surface. I used it on the transmission case above and it went from that old splotchy aluminum to the uniform darker grey that you see in the pic. I also used it on my TD intake and exhaust manifolds. Supposedly it cures with heat and can be used on any bare metal. Just wondering if anyone has some long-term experience with it and if it stays looking this nice for a while.
Here are before and after shots of my brother's 69 Camaro headers I just did:
Nasty:
I bead blasted them, after which they looked OK, but not beautiful. Then spent about 2 hours applying the Calyx:
The difference is amazing. So far I'm really impressed with this stuff. I just hope they stay looking this good...
Erik Miller
Reply #20
March 24, 2012, 12:20:14 am
funkaholik
Engine is IN!!
Reply #20 on:
March 24, 2012, 12:20:14 am »
New engine and trans are finally in! After many months of work, she finally fired up. Nailing hard, shut down right away and checked injectors: 2 are leaking bad. Followed Giles' advice and repeatedly pop tested to clear possible dirt, but to no avail. Got them to a local diesel guy to take them apart and get them fixed (not in my skillset). Hopefully ready for action this Monday...
Erik Miller
Reply #21
March 26, 2012, 07:03:44 am
DieselBalz
Re: Engine is finally IN!!
Reply #21 on:
March 26, 2012, 07:03:44 am »
Looks really clean. Nicely done sir.
Reply #22
March 26, 2012, 10:36:26 am
gnavs
Reply #22 on:
March 26, 2012, 10:36:26 am »
I noticed in the very first picture that you have the old style crank pulley with the notch. Maybe I can't see it because of hte bolt but you did upgrade to the TDI style sprocket, right?
That metal polish looks like it works great. I'll have to hit my transmission with that stuff at some point. Wonder how long it lasts...
Keep up the good work!
Reply #23
April 02, 2012, 11:45:23 pm
funkaholik
Reply #23 on:
April 02, 2012, 11:45:23 pm »
I am running an old-school v-belt on the alternator (this is a 1.6TD). If I'm correct, the TDI sprocket is for a serpentine setup, right?
Erik Miller
Reply #24
April 03, 2012, 05:30:42 am
chrisg
Reply #24 on:
April 03, 2012, 05:30:42 am »
the TDI sprocket runs the timing belt, then a serp OR a v-belt pully bolts to it. you can put a tdi sprocket on your car and still run v-belts
Reply #25
April 04, 2012, 12:24:39 am
funkaholik
Reply #25 on:
April 04, 2012, 12:24:39 am »
Got it. I did not upgrade to the TDI style sprocket. Still running the stock 1.6 TD part.
Erik Miller
Pages:
