Author Topic: Sealing paste for oil spray nozzles. What is it?  (Read 5052 times)
December 02, 2011, 10:54:42 am
wil892
  • 216
« on: December 02, 2011, 10:54:42 am »
Hi
I just got home for the weekend to assemble the bottom end of the engine, only to see I need some sort of sealer paste to install the oil spray jets or oil squirters as they are known.
The bentley lists AWV 188 100 102, which I cannot get hold of. What have other people being using? I have bought some new bolts from VW and have the red loctite to put on them.
Would Loctite Aviation Gasket Sealant be any good? It says temperature resistant to 400 F, but nothing about compatibility with oil. Its the brown stuff.
Its the only thing stopping me at the moment!! :(
1991 Golf MK2 GTD
Reply #1December 02, 2011, 11:04:16 am
Re: Sealing paste for oil spray nozzles. What is it?
« Reply #1 on: December 02, 2011, 11:04:16 am »
i would not be afraid to use AV sealer. or even high temp RTV..
Reply #2December 02, 2011, 11:41:54 am
wil892
  • 216
« Reply #2 on: December 02, 2011, 11:41:54 am »
Yeah I think AV sealer would work well, have you used it before? Any other people used other stuff with good results?
1991 Golf MK2 GTD
Reply #3December 02, 2011, 12:51:06 pm
rodpaslow
  • 670
« Reply #3 on: December 02, 2011, 12:51:06 pm »
I've used the red/copper RTV with good success.  My opinion only, make sure the hole is as clean as you can get it (I normally do this before pistons are installed on engine stand).  Do not over do it with the stuff.  Clearance between the hole and squirter is likely only .002-.005"
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
Reply #4December 02, 2011, 04:24:36 pm
« Reply #4 on: December 02, 2011, 04:24:36 pm »
I would use Permatex thread sealant which you can get at NAPA, or just plain old RTV.
The aviation sealer doesn't ever really get hard, so I don't think it would seal a bolt that is subject to vibration. It's good for flat gaskets on these engines though.
Reply #5December 05, 2011, 03:09:29 pm
monomer
  • 414
« Reply #5 on: December 05, 2011, 03:09:29 pm »
I thought green Loctite would be the choice for this application.
"retaining loctite" It's what I used to use to hold drill bushings in place. Strong ***, as long the hold is reamed close to size.
-1983 Rabbit LX 1.6/1.9 VNT build
Michigan Volkswagen Enthusiasts
www.michiganvw.org
Reply #6December 05, 2011, 03:55:45 pm
kevinm
  • 78
« Reply #6 on: December 05, 2011, 03:55:45 pm »
is this rtv to go around the taper part of the oil squiter... or the screw that draws it in...
Reply #7December 05, 2011, 09:57:50 pm
  • 2931
« Reply #7 on: December 05, 2011, 09:57:50 pm »
 Lock tite on the bolt and ultra grey,.. or I use ultra black to seal around the part sticking into the block.
Reply #8December 06, 2011, 01:06:58 am
wil892
  • 216
« Reply #8 on: December 06, 2011, 01:06:58 am »
I used red loctite 542 on the bolt holding the squirter in. Then aviation gasket sealer around the stem and part which enters the block. AV sealer is so sticky and does almost set I think so hopefully should be ok
1991 Golf MK2 GTD
