Author Topic: Blown oil seals, upgrade to VNT?  (Read 10682 times)
Reply #30November 30, 2011, 10:11:34 am
MJF
  • 581
Re: Blown oil seals, upgrade to VNT?
« Reply #30 on: November 30, 2011, 10:11:34 am »
non working vnt is like having a non vnt turbo.
Like a non-vnt turbo without a wastegate actually...
how many other non-VNTs do you know of that will spool @ 1500 revs, and be making full boost by 2800 revs, and still pull till 5500 revs?
Not in stock engine, but my friends Schwitzer S2B hybrid boosts 0,8bar/2000rpm in AAZ. 260+hp. There are differences between turbos...
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #31November 30, 2011, 10:19:03 am
« Reply #31 on: November 30, 2011, 10:19:03 am »
yea, mines a stock engine, and a stock turbo, with a stock pump.
Reply #32November 30, 2011, 10:23:25 am
« Reply #32 on: November 30, 2011, 10:23:25 am »
Frederickk, if i were you, and was debating a VNT, then i would jump on the train and go for it. you wont regret it.
i remember, back when i built my engine, there were only a HANDFUL (maybe a half dozen) older VW diesels using the VNT turbo, and now its a fairly common swap.
the info is out there now, there has been enough research and development (destroyed engines) now to know the limits of things, and such.
