Author Topic: k14 highway psi  (Read 25017 times)
Reply #45November 18, 2011, 12:23:54 pm
Re: k14 highway psi
« Reply #45 on: November 18, 2011, 12:23:54 pm »
u guys are so FOS it's pathetic...get a room already.
Watch this and learn something...
http://www.youtube.com/watch?v=ZHVXbKD5IPk
Carry on.
Such a nice car :)
Reply #46November 18, 2011, 12:31:20 pm
ilikevwdiesel
  • 1202
Re: k14 highway psi
« Reply #46 on: November 18, 2011, 12:31:20 pm »
I believe it's pretty flat in NE ohio (like the top of your head maybe?), we're talking about the SF Bay area. Ever been there?
Fisherman's Wharf. Bay Bridge. Yep, been there.
FWIW, I drove the car back from North Carolina when I bought it dead stock with the original AVX trans, which you may know has the tallest of all VW transmission R&Ps: 4.25:1. The car barely got out of it's own way. It was dangerously underpowered; 65 mph with the pedal mashed running up the mountain highways. I vowed right then that I would make it run better, which I have, with help from this site. Gearing is just one performance metric. State of tune is another equally important metric. I've since driven my modded Jetta on those same mountan roads. It easily pulls the tall gears on long, steep grades without downshifiting and runs all day with the left laners at arrestable speeds. Low gears are good for the track or an autocrosser, which that 4.25:1 gear set ended up in.
the AVX is the LOWEST geared trans, not highest. the ACN type, and F type trannies were the highest geared. you could either get a 3.67 with a .75 5th gear, or a 3.89 with a .71 5th gear..
anyways, the AVX should have been screaming at 65mph..
but, point of the story being, that an ACN trans, or something similar is a PERFECTLY GOOD MATCH for a 1.6TD.
ilikevwdiesel is the only user on the forum that says the high geared trannies are no good for the torquey diesels. but they are fine for the gutless 1.8L 8v engines they came stock behind..
theres some flawed logic somewhere in this derailed topic..
Yes, lowest; you know what I meant. 80 mph tops with a tailwind with the AVX and it sounded ready to gernade. 65 mph up the mountain roads limited by power, not gearing. My point is, even with low gears (ala AVX) the car can still be a dog, which mine was.
OH!! gotcha.. yea, makes sense now..
my car has 3.67 gearing, and its quicker now than it was with 3.94's..
lol, 80mph with a tailwind.. that reminds me of driving a n/a w/ a GC 4 spd.. the best my n/a's will do with stock government, is 83mph, down hill, on the governor.
whats your problem dude? who pissed in your cheerios? you are basically saying that 3.67 gears cant be used with a TD.. or any diesel for that matter! the acn trans is the highest trans VW produced, and came behind the lowest HP engine they ever produced. if it works fine on an engine that has no turbo, and a peak torque at about 3 grand, then WHY THE F**K WONT IT WORK WITH A TD?!
i have a VNT on my engine, i can make boost low enough that i could honestly probably run a TDI trans with its rediculous ratios and still be fine. i could probably still accelerate up any hill..
but seriously? WTF IS YOUR PROBLEM?
you pissed off because we said it can be done?
well guess what, an ACN TRANS IS A GREAT MATCH FOR A TD!!!
you basically claim that a 16v trans is the kind you want behind a diesel.. your F***ING high..
i want high gears, not low gears. i would rather have to shift once in a while, rather than be basically wound out going 80 mph..
anyways, do us all a favor, and remove yourself from this thread. you arent helping it one bit. this is turning into a battle of the opinions..
its been gone over a bazillion times.. the diesels get better mileage with taller trannies, but they suffer some acceleration because of the longer gears. thats mostly only true on stock cars.
anyways, this is completely useless to keep arguing.. i can see you wont accept logic..
what are you trying to accomplish here anyways dude? your just getting all pissed off because we said you are wrong..
you are THE ONLY USER ON THE FORUM, who advises AGAINST using 3.67 gearing. anyone with half of a brain knows that 3.67 gears are better for a diesel. when people ask about tranny swaps, the most common answers are "swap in an ACN/AON/ASF/ACL, because they are easy to find, they came in econo-box jettas and golfs." the next most common response is: "swap in a F series (ff, fn, fh, fj) transmision, they were fairly common in rabbits"
and why are you getting soo mad? an AGS is the almost the same thing as an ACN, but with lower gearing. have you actually ever ran a good running TD with an ACN behind it? because i have, and it is AWESOME. ACN is my favorite stock trans, hands down.
if you are trying to make your diesel feel like a GTI, with short gearing, then by all means, use an AGS, or AVX, or AUG, or whatever..
my diesel was funnest to drive with the AUG in it. but it performed much better with the ACN trans in there. mileage was considerably better too..
I'm not mad...u mad bro?
My Bio
Reply #47November 18, 2011, 12:35:43 pm
Re: k14 highway psi
« Reply #47 on: November 18, 2011, 12:35:43 pm »
well, from that last comment, it could be interpreted that you are aggravated, because of the name calling. im assuming FOS is some sort of abbreviation for a bad name.. and then saying to go get a room? thats not something you usually say to someone unless you are aggravated with them.. ive never heard the response "get a room" used in any way besides a negative manner..
negative comments get negative responses..
Reply #48November 18, 2011, 12:44:59 pm
ilikevwdiesel
  • 1202
Re: k14 highway psi
« Reply #48 on: November 18, 2011, 12:44:59 pm »
Carry on.
sounds like your timing belt is a little tight...
My Bio
Reply #49November 18, 2011, 01:02:45 pm
larry104
  • 200
Re: k14 highway psi
« Reply #49 on: November 18, 2011, 01:02:45 pm »
Carry on.
Only if factory spec is a "little tight." 30K on the belt.
Reply #50November 18, 2011, 01:11:21 pm
Re: k14 highway psi
« Reply #50 on: November 18, 2011, 01:11:21 pm »
May I suggest an alternative site for those interested in screaming at eachother in a forum: http://vwvortex.com/
See a few pages back where Dieselstink and I were discussing something?  See how I decided I had it wrong based on the evidence?  See how neither of us insulted one another, called eachother names or implied anything about one another?
Please feel free to use the PM function if you want to have off topic rants at one another, I'm sure the rest of us would appreciate it.
Reply #51November 18, 2011, 01:12:09 pm
larry104
  • 200
Re: k14 highway psi
« Reply #51 on: November 18, 2011, 01:12:09 pm »
Carry on.
Such a nice car :)
Thanks. It will be one of the few cars I'll dearly miss if something were to happen to it. That said, I was ready to shove it off a cliff until recently when I finally figured out how to fix the alternator belt drive. The bad part was, it would spin the alternator fast enough to keep the light off, but not enough to adequately charge the battery. The only clue it was happening was that the temp and fuel gauges read a little low. The car stranded me more than a few times. It's been flawless since -- knock on soot.
Reply #52November 18, 2011, 01:16:30 pm
Toby
  • 728
Re: k14 highway psi
« Reply #52 on: November 18, 2011, 01:16:30 pm »
Also agree 100%...  Wastegate wouldn't be open till 10PSI no matter what, assuming it is set for the 10-12 PSI factory spec.
Actually typical wastegate actators are not binary. If the boost is regulated at 12 psi the begin bleeding off exhaust somewhere below that pressure and should be fully open at 12 psi. That is why the Gillis valve is so popular. No pressure is applied to the WGA until the target pressure is reached, unlike stock set ups.
Reply #53November 18, 2011, 01:31:41 pm
92EcoDiesel Jetta
Re: k14 highway psi
« Reply #53 on: November 18, 2011, 01:31:41 pm »
[/quote]
My lawnmower alternator belt's been fine. Only adjusted it once since I installed it. It's been about 6000 miles and not one squeal with all the elec load I can throw at it, even in the rain!
Reply #54November 18, 2011, 01:35:27 pm
larry104
  • 200
Re: k14 highway psi
« Reply #54 on: November 18, 2011, 01:35:27 pm »
[/quote]
Excellent!  8)
Reply #55November 18, 2011, 06:06:37 pm
Mark(The Miser)UK
  • 1557
Re: k14 highway psi
« Reply #55 on: November 18, 2011, 06:06:37 pm »
So the LDA does come in to play then.  However is the total amount of fuel being injected different because the LDA called for it vs the accelerator pedal, or is it the same?  So regardless if the LDA is connected or not, he gets the same boost at the same road speed... So will adjusting the LDA make any difference to his fuel consumption?
I would say that in this case because the LDA is maxed out in either case, the amount of fuel is the same and adjusting the LDA won't change his fuel economy for highway cruising.  If he gets the rest of the car dialed in so that he isn't always maxed on boost at freeway speeds, then adjusting the LDA will affect his fuel economy by reducing the amount of boost and back pressure necessary for that load.
Agree 100%... :)
If he has disconnected it and still gets 10 psi I would say that he needs to start looking at wastegate for sure now. He said his trans earlier and IIRC final 3.67 and 5th is .75.
If the wastegate is regulating boost consistently to 10 psi, then it is working properly.
I'd like to be convinced that another vehicle running the same speed, but running at 5 to 10psi is running as economically. If they are then either their turbo is more efficient at extracting energy, or less energy is going to coolant and more out of exhaust. I suspect that mostly it is more fuel being burnt, so as the rate of distance coverage is the same, the engine is less efficient, so effectively running richer.
Hey Mark, what is your 70 MPH cruising RPM and what turbo do you have?  Both of those are factors too...   More heat is going to his turbo than yours, but that can be caused by higher engine speed, retarded timing (we've eliminated that one for him already), dragging brakes, bad alignment, bad wheelbearings, hills, headwinds, etc.  You could (theoretically) also have a much more restrictive exhaust than he does, though I'm not sure that would make up for that large a difference.
Actually, was there any change in your cruising boost before/after your new rings?
10 psi at 70 mph (around 3,000 rpm)
This one is confusing me... (the 3K RPM bit)... Based on your transmission code, you'd need to have tires that were only about 21" tall to have that engine speed.  Are you running 13" wheels with low profile tires?
My Quantum is running the standard 3M g/b. Revs at 70mph are a little over 3000rpm. It used to be a little under, but that was when I used the 13" by 185 tyres. I now only run 13" x 175's I think they are x 60 depth. I found they grip the road better and do not track the ruts so much, which is kind of counter intuitive.
Strangely running tyres at 40psi all round, after they warm up, it may drop a few revs to be almost exactly 3000rpm.
When the engine had ringgaps you could walk through, cruise psi was about the same, possibly slightly higher. What the  rering did most was to change my cruise mpg by up to 15mpg, but leaving the town mpg only a few points higher.
The smoke on acceleration has almost disappeared, along with the start up smoke. 5 seconds of bosch glowplug is sufficient. [non Duraterm]
Turbo I think is a KKK. Maxes out at a standard 10psi or so.
Tomorrow I hope to hit near 60mpg [UK], as I'm on a rare long trip of about 160miles.  Muddying the waters slightly is that I upped the internal pump idle pressure, from 18psi to 40+ so part of my 'stable' mpg values may have been due to poor dynamic advance.
Mark-The-Miser-UK
Reply #56November 18, 2011, 09:29:09 pm
damac
  • 531
Re: k14 highway psi
« Reply #56 on: November 18, 2011, 09:29:09 pm »
I am running stock tires on my car.
I am getting around 43mpg right now with the car.  Alignment, all new suspension, etc.
With that acn tranny its a pretty fun car to drive around town in gears 1-4, but then again i am no racer.
25% of that commute is up/down twisty mountain pass and the rest is freeway at 70mph.
On those hills I was very surprised to find that I could pull everything in 3rd gear if I really wanted although a few spots would make the car really lug so I shift.  But I don't need to go crazy on that part as far as shifting like I thought I would.  5th gear is doable in traffic on flat ground :)
I can really go nuts with this setup around town and rev the hell out of the car and it seems to pull well.
1985 turbo diesel jetta
Reply #57November 19, 2011, 12:35:11 am
Re: k14 highway psi
« Reply #57 on: November 19, 2011, 12:35:11 am »
43 MPG US sounds pretty darn good to me!! That's about 5.3L/100KM Canadian.  Better than a Prius... :)
Reply #58November 19, 2011, 08:53:26 am
Re: k14 highway psi
« Reply #58 on: November 19, 2011, 08:53:26 am »
if your trans says ACN on the bottom, and you turn 3k going 60mph, then someone had the 5th gear swapped out at some point, or the whole case has been replaces, and its just an ACN case with a mystery gear set in it.
my gasser with stock 185/60/14s and a stock ACN trans will turn 3k @ ~73mph.. and i get 35 mpg.. not bad for a gasser, but certainly not diesel numbers for sure..
Reply #59November 19, 2011, 09:32:21 am
lilpig88
  • 18
Re: k14 highway psi
« Reply #59 on: November 19, 2011, 09:32:21 am »
Thanks again!
Looks like after a little sidetrack the conversation is heading in a valuable direction again.  It's a mere 5 degrees F at the moment here in MT but I might head out later to check my timing.  Not more than 2 month ago when I put this pump on I set it at 1.05mm.  A few folks have mentioned to get my pump "dialed in" which I completely agree with and that's why I began this thread (not expected such a long one).  So I'm curious if there are any more recommendations for "dialing in" this pump.  There seemed to be a supported thought that maybe I'm a little under-fueled?  I can adjust the LDA pin orientation to get smoke under full load (and I've pulled back this setting a bit)...this seems to tell me I've got adequate fuel?  maybe? Anything I should try even if it's for experimental purposes for you all to learn something?  Max fuel screw?
The car seems to drive wonderfully around town and I like the power but while I can drive 80 down the interstate if need be, I feel it should cruise this speed with a little less oomph than it needs at the moment and without such high boost.
I don't want to go looking for a problem, but am simply trying to figure out how to best tune this thing.
Thanks again!
