TDI Engine -General Info
Need some advice or opinions
Topic: Need some advice or opinions (Read 3503 times)
November 06, 2011, 02:04:20 pm
chopper03
User+
November 06, 2011, 02:04:20 pm »
I have got a 1z tdi motor from a 96 Passat with the 5 spd cable shift trans.
I want to put in my 82 Caddy truck.
I also have a 12mm bosch mechanical idi injection pump that i would like to use.
Can anyone tell me which injector nozzles and turbo I would need to use for the best
performance with the 12mm pump.
Or will this pump even work as is, Or do I need to install the tdi camplate ?
November 06, 2011, 08:11:49 pm
410
Re: Need some advice or opinions
November 06, 2011, 08:11:49 pm »
What did the idi 12mm pump come from? Was it a stationary/industrial engine? If so the camplate isn't the only thing you need to worry about. You'll need to look at the advance curve and the governor as well.
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles. Sold!
November 07, 2011, 02:06:52 am
chopper03
User+
November 07, 2011, 02:06:52 am »
I don't really know, I bought it from e-bay its new bosch I looked the numbers up and
it says hercules 4 cylinder 2400 rpm. I will get the number from the pump ans
post it tonight.
November 07, 2011, 10:17:30 am
410
November 07, 2011, 10:17:30 am »
Would you be able to post a picture of the pump?
November 07, 2011, 05:00:14 pm
chopper03
User+
November 07, 2011, 05:00:14 pm »
pictures of pump
now lets see if this works
