Author Topic: Why is my mileage so much lower than others claim?  (Read 9715 times)
Reply #30November 11, 2011, 06:47:50 pm
Re: Why is my mileage so much lower than others claim?
« Reply #30 on: November 11, 2011, 06:47:50 pm »
What vintage cars are we talking about? I have never seen any kind if spring loaded vent on any diesel VW that I have owned. Most of mine have been older stuff though.
MK2 gas and diesel afaik, I just checked my '92 golf diesel and it has it. It's just a little lever inside the neck towards the rear of the car that you push IN and it opens it.
I don't know about anything newer.
« Last Edit: November 11, 2011, 06:58:44 pm by rabbitman »
Reply #31November 12, 2011, 06:33:20 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #31 on: November 12, 2011, 06:33:20 am »
I think you need to wax your car. Less wind resistance  ::)
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #32November 25, 2011, 07:51:43 pm
cervelorod
  • 41
« Reply #32 on: November 25, 2011, 07:51:43 pm »
I put a gauge on my IP this evening and I had 20 psi at about 1100 rpm.  Guessing on the RPM part...  I increased the pressure to 43 psi.  I did only a short drive and didn't notice a difference in performance.  I put my gps in the car and am going to check odometer and speedometer, also upgraded this week, then keep fuel economy and see if it makes a difference.
Rod
