Engine Specific Info and Questions > TDI Engine -General Info
Common TDI Issues (PLEASE MAKE STICKY)
catlin_cava:
--- Quote from: Powered by Spearco on October 18, 2011, 11:59:20 pm ---How about the flashing glow plug light that can mean that brake light bulbs are burnt out.
--- End quote ---
must be a US thing, :P
Flashing GP light will the car is running usually means a fueling issue,
GTiTDi:
The flashing glowplug light can mean much more than a fueling issue, often times it is a result of a failed or misadjusted brake light switch, glow plug circuit issues, etc.
745 turbogreasel:
Does this connect with #4 bad glow plug code...when that plug is fine
BECAUSE OBD #s the glow plugs in reverse??? 02 ALH
A friend of mine tells me she's only had one issue in like 5 years...sometimes when boosting up a hill, it loses power until she removes and replaces the fuel cap. Clever girl, but what's the real solution?
theman53:
http://forums.tdiclub.com/showthread.php?t=310218&highlight=smf+clutch
http://forums.tdiclub.com/showthread.php?t=340137&page=2
Best threads I found explaining what clutch setup to use for the SMF in TDI.
http://www.jimellisaudiparts.com/showAssembly.aspx?ukey_product=5448339&ukey_assembly=751739
smutts:
Vibrating belt tensioner pulley, usually a seized (siezed?) freewheel pulley on the alternator.
But when I sorted my knackered freewheel pulley, I was disappointed that there was more flapping of the tensioner than I would like.
When the idler pulley fell (melted!) off a few months later... "rattle clunk tinkle" bye bye power steering, hello hedge! Once replaced, the tensioner was dead steady. So tensioner vibration can also be due to a dying idler pully. ;)
Navigation
[0] Message Index
[*] Previous page
Go to full version
