General Information
Upgrades (non engine related )
Can I make my mk3 calipers work on my mk1?
Pages:
Topic: Can I make my mk3 calipers work on my mk1? (Read 23925 times)
Reply #15
October 10, 2011, 05:02:37 pm
Re: Can I make my mk3 calipers work on my mk1?
Reply #15 on:
October 10, 2011, 05:02:37 pm »
I think just venting the 9.4's will only help with fade and not with braking power though right?
Reply #16
October 10, 2011, 06:03:17 pm
vanagonturbo
Reply #16 on:
October 10, 2011, 06:03:17 pm »
correct. You can put 10.1" on there with vented rotors.
Reply #17
October 10, 2011, 06:22:56 pm
Reply #17 on:
October 10, 2011, 06:22:56 pm »
Then 10.1 I will go
I just need to find some 16v rocco or 83-87 audi 4000 quattro carriers
thank-you guys
Reply #18
October 10, 2011, 07:00:48 pm
Reply #18 on:
October 10, 2011, 07:00:48 pm »
exactly.. you understand why i did big brakes way back all them years.. for silly stupid stuff when out alone.. and yep 16v rocco/audi 4kq..
i was out in the toaster sunday on a "cruize" thru cleveland parks aka 70mile ish treck thru the parks.. with lots of other vws... and the oppertunity to screw around was pretty good... 11" were impressive and with said group... i always leve room infront of me vs the tailgaters behind me.. i think i have a few wondering wtf.. how the hell does a diesel run like that.. a box turn like that.. and slow down like that...
was still running 18-21psi and with the elevation changes and twisties could upset the toaster enough to lay rubber with ease in 2nd or 3rd..
the rolling starts out of parking lots.. ripping free in 1st (aka not from dead stop) then into 2nd with a chirp into 3rd from the icecream stand gotta be priceless..
get the rover pump... do the 02a... yes i saw the build tdi-m pump.. mine is so silly... if you goto play.. your going to break the 020... may not be right off the bat.. but it will break soon or a later.. and will be a inoppertune time when it does..
Reply #19
October 10, 2011, 08:24:06 pm
Reply #19 on:
October 10, 2011, 08:24:06 pm »
think ill upgrade the rears to 200mm drums while I'm at it
Reply #20
October 10, 2011, 08:42:05 pm
Reply #20 on:
October 10, 2011, 08:42:05 pm »
i wish i could upgrade to disks on toaster... till i build a new rear axle.. no way i can fit the wheels for such a thing.. but 200mm seems ok for now..
pm replied too... get back with me on the tech school idea if you can pull that off..
for others.. 20+ years ago in high school.. my tech school had silly night classes.. say 10 weeks of 2 hours a night 2 nights a week learn to weld so on... i was filled during the day there as is.. but they had a tig/mig class at night that was not offered during normal school hours.. back then it was 50$ and hell i blew 10 weeks learning tig.. you could bring any projects from home to play with...
so check with your local schools.. maybe there is a place where you can build your own mounts for next to nothing.. or a cnc class to do some machine work even.. IMO well worth the knowledge.. and heck if you need to build something for your project.. maybe a way to make it reality..
me off to buy f4.. then come back for f3 race night...
Reply #21
October 11, 2011, 03:25:48 pm
Reply #21 on:
October 11, 2011, 03:25:48 pm »
Rock Auto $25 ***IN!
Reply #22
November 11, 2011, 05:34:14 pm
GEE-BEE
Reply #22 on:
November 11, 2011, 05:34:14 pm »
http://www.momentummotorparts.com/store/newproduct.asp
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #23
November 11, 2011, 08:14:16 pm
Reply #23 on:
November 11, 2011, 08:14:16 pm »
Gee-Bee! Beautiful as usual my good man!
Tad out of my price range (also as usual
lol), but a great link to have in this thread. Thank-you
Reply #24
November 12, 2011, 12:09:36 pm
Reply #24 on:
November 12, 2011, 12:09:36 pm »
if your mk1 has 1 piece caliper brackets, then it wont work. my early mk2 also had 1 piece caliper brackets, and i had to swap knuckles to swap brakes..
mk3 should be 10.1 brakes. and dont most mk1 cars have integrated knuckles/brackets?
Reply #25
November 12, 2011, 06:57:10 pm
Reply #25 on:
November 12, 2011, 06:57:10 pm »
I think the integrated is a Westy only thing.
All three of my mk1 Jetta's (aka Wolfsburg built) have knuckles that will accept the carriers i posted above. Which will allow a 10.1 bolt on caliper.
Reply #26
November 12, 2011, 10:37:32 pm
Reply #26 on:
November 12, 2011, 10:37:32 pm »
mk2 stared integrated...
Reply #27
January 05, 2012, 04:38:18 am
vwabbitman
Newbie
Reply #27 on:
January 05, 2012, 04:38:18 am »
I put gti vented rotors on my mk1 pickup I think 7-8 years ago, changed pads 4 years ago for some not so cheaply made ones and they still have minimum 2 years left in them. With old solid rotors I had to replace pads every 1.5-2 years. Old pads from non vented rotors were reused since they were the perfect thickness for the thicker vented rotors(barely). Had no fad even after going down a two mile hill. Carrying weight (1000lbs+) still no obvious fad but stopping distance was doubled. Im planning on putting 10.1 rotors and calipers on for the extra stopping power. Just need carriers.
www.humboldtvw.net
"Respect my Athority!!!"
Reply #28
January 05, 2012, 11:07:09 pm
Reply #28 on:
January 05, 2012, 11:07:09 pm »
Rock auto. $25!
Reply #29
January 06, 2012, 02:24:09 am
vwabbitman
Newbie
Reply #29 on:
January 06, 2012, 02:24:09 am »
Quote from: 8v-of-fury on January 05, 2012, 11:07:09 pm
Rock auto. $25!
Was gonna look at that last night but got side tracked.
Btw didn't you live in redding ,ca a few years ago? I remember a vw guy I talked to there and I swear it was you.
www.humboldtvw.net
Pages:
General Information
