Author Topic: yellow dot pump on a 1.6  (Read 13849 times)
Reply #30August 28, 2011, 11:25:59 am
mtrans
  • 308
Re: yellow dot pump on a 1.6
« Reply #30 on: August 28, 2011, 11:25:59 am »
I'm not saying that 90bar is sufficient, but my best mileage straight after my rering last year had the injectors down to 125 bar
Is this for diesel only?
I`ll improve my English
Reply #31August 28, 2011, 11:33:55 am
« Reply #31 on: August 28, 2011, 11:33:55 am »
gassers dont run that high of a fuel pressure, so, yea, its a diesel only thing.. (1350psi)
Reply #32August 29, 2011, 09:12:19 am
  • 2932
« Reply #32 on: August 29, 2011, 09:12:19 am »
 Yep, yellow paint on the front timing cover,.. but not all 107As are yellow dots,.. that just means it's a 1.5 pump.
Reply #33August 29, 2011, 10:38:55 am
mtrans
  • 308
« Reply #33 on: August 29, 2011, 10:38:55 am »
Thanks man I know little about disel/gassers, the reason I ask is that in GB is in use VVO(legal up to 2000 lit?) or bio/same oil?
Reply #34August 29, 2011, 10:42:06 am
« Reply #34 on: August 29, 2011, 10:42:06 am »
sorry, i couldnt make sense of that post.. usually i can, but not this one..
Reply #35August 29, 2011, 02:38:27 pm
Mark(The Miser)UK
  • 1557
« Reply #35 on: August 29, 2011, 02:38:27 pm »
WVO? 2500 litres per year allowed now in UK.
Generaly need to run higher injector pressures. However, I stick 10 % clean cannola into the tank once a month or so, with no issues.
Mark-The-Miser-UK
Reply #36August 30, 2011, 12:16:34 pm
mtrans
  • 308
« Reply #36 on: August 30, 2011, 12:16:34 pm »
Hi Mark!
Do you use 10 % clean cannola because of ULSD,our engine is made for D2.
Reply #37August 30, 2011, 03:11:43 pm
Mark(The Miser)UK
  • 1557
« Reply #37 on: August 30, 2011, 03:11:43 pm »
Hi Mark!
I do it partly to see how performance is affected, and partly because its 25% cheaper than ULSD when on offer and because it seems to run fine and smell good. ;D
I used to run pure, and run it from the headlight washer tank in the engine compartment, as it conveniently was about 1 ft away from the injection pump.
I used to get similar performance, and mileage.
Maybe I'd get better results running pure now I've rebuilt [reringed] the engine.
Doesn't our  Euro diesel contain 5% bio? I have some WVO, but I really need to filter it.
Mark-The-Miser-UK
Reply #38August 31, 2011, 12:20:51 pm
mtrans
  • 308
« Reply #38 on: August 31, 2011, 12:20:51 pm »
Hi Mark!
Yup min 5%,but I don`t like WVO even VO is cheaper,I prefer 2t oil by advice from hagar the great or same alse oil.
Reply #39August 31, 2011, 12:39:45 pm
Mark(The Miser)UK
  • 1557
« Reply #39 on: August 31, 2011, 12:39:45 pm »
Hi Mark!
I'm guessing, but WVO from a vegetarian restaurant would be easier to use, wouldn't it?...
Mark-The-Miser-UK
Reply #40September 01, 2011, 11:14:54 am
mtrans
  • 308
« Reply #40 on: September 01, 2011, 11:14:54 am »
Ha,ha could be but here vegetarian restaurant is rare.
Reply #41September 18, 2011, 10:34:40 am
« Reply #41 on: September 18, 2011, 10:34:40 am »
here is the video of my car doing 0-60, this with stock everything, and my pump timed to 1.13.
http://www.youtube.com/watch?v=dQ23ceaRk-s
« Last Edit: September 18, 2011, 03:34:43 pm by Trev0rbr »
Reply #42September 18, 2011, 02:25:29 pm
92EcoDiesel Jetta
« Reply #42 on: September 18, 2011, 02:25:29 pm »
yellow dot pumps have a bunch of yellow paint all over the advance mechanism cover and also their part number ends in 107a
Who would use yellow paint to mark a pump? I hope not Bosch! Shouldn't it be something more permanent like a part number stamped into the housing?
Reply #43September 18, 2011, 03:36:50 pm
« Reply #43 on: September 18, 2011, 03:36:50 pm »
yeah it was bosch, a lot of pumps have the yellow stuff on them just on adjustment screws and such
