Author Topic: euro ford diesel 4 banger??? say 85ish.. do they exist????  (Read 8948 times)
August 20, 2011, 08:40:44 pm
« on: August 20, 2011, 08:40:44 pm »
ok i have a oppertunity to make some coin.. 2 85 grumman kub vans.. sadly they have ford temp engines in them... and subframes and all kinds of goofy crap...
originally i suspected they took a vw kubvan.. added a ford engine... NOPE... complete redesign...
guy really wants a diesel one.. he is sick of his 17mpg.. i could in theory build new mounts.. build a complete new set of axels to mate vw to ford suspention... but in a way... id hate to mod a odd duckling how many of those did they make... kinda wanna keep it ford powered.. even if he needed to import a engine..
Reply #1August 21, 2011, 06:28:06 am
hustonr123
  • 124
Re: euro ford diesel 4 banger??? say 85ish.. do they exist????
« Reply #1 on: August 21, 2011, 06:28:06 am »
AT my job there is 2 ranger diesels and a escort diesel. there all in the 80 to 85 range.  all for sale CHEAP
Reply #2August 21, 2011, 07:01:03 am
catlin_cava
  • 1954
« Reply #2 on: August 21, 2011, 07:01:03 am »
a buddy of mine has 2 of those motors, and a ranger diesel lol
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #3August 21, 2011, 07:53:07 am
« Reply #3 on: August 21, 2011, 07:53:07 am »
http://www.crsmp5.com/ford_kub/home.htm
sending you pm on the escort diesel..
Reply #4September 01, 2011, 04:20:34 am
rs899
  • 647
« Reply #4 on: September 01, 2011, 04:20:34 am »
The engines that Ford used to power the Escorts and Tempos in the 80s was made by Mazda.  IIRC, not a bad engine if you can find the parts to keep it going.
Reply #5September 01, 2011, 06:52:39 pm
catlin_cava
  • 1954
« Reply #5 on: September 01, 2011, 06:52:39 pm »
100$$$ some for 1 Glow Plug
Catlin
Reply #6September 03, 2011, 02:39:39 pm
hustonr123
  • 124
« Reply #6 on: September 03, 2011, 02:39:39 pm »
When are you coming after this escort got it started and driving around yesterday.
Reply #7September 03, 2011, 08:06:19 pm
« Reply #7 on: September 03, 2011, 08:06:19 pm »
did you talk to the guy with the kubvan? aka kevin? i have not talked to him since i told him about it.. then i gave you his #
Reply #8September 04, 2011, 07:19:33 am
hustonr123
  • 124
« Reply #8 on: September 04, 2011, 07:19:33 am »
Yea I talked to Kevin the other day
Reply #9September 04, 2011, 08:27:08 am
« Reply #9 on: September 04, 2011, 08:27:08 am »
i have not heard from him.. so did not know if he was buying or not..  :P  ill give him a call today to see what is up..
Reply #10September 04, 2011, 09:30:33 am
hustonr123
  • 124
« Reply #10 on: September 04, 2011, 09:30:33 am »
Yea he is coming down a day this week. I just learned that vw shim disk fit that motor so I'm gonna adjust the valves. Timing setting is also the same as vw and the  Pump tools work.  I thought it seemed off I will check that also.
Reply #11September 27, 2011, 07:46:10 pm
« Reply #11 on: September 27, 2011, 07:46:10 pm »
Reply #12October 02, 2011, 09:57:04 am
« Reply #12 on: October 02, 2011, 09:57:04 am »
the old tempos had 2.3L 4 bangers.
the old escorts had 1.9L 4 bangers.
both built by ford..
Reply #13October 03, 2011, 02:00:48 pm
danster
  • 71
« Reply #13 on: October 03, 2011, 02:00:48 pm »
In Euroland we got the mk3 Escorts (first of the transverse engined fwd one) with a 1.6 diesel engine. There then came a 1.8 which came with a few subtle differences.
These were Ford engines, we did not have the Mazda tie up over here. The engine was actually fitted to a number of Ford vehicles and later wore a turbo in some applications including the Focus model.
The block to gearbox bellhousing bolt pattern was the same as the Petrol engines so that should match the Ford 2.3 SOHC petrol engines you got over in the states iirc.(engine called Pinto in UK, not the same as the Pinto car you got).
Can get more info if you want. Just let me know.
Reply #14October 08, 2011, 07:39:38 am
« Reply #14 on: October 08, 2011, 07:39:38 am »
http://www.crsmp5.com/86_kub_ford/86_kub_ford.htm
the blue one thats sitting outside... work.. work i say... needs lots of tlc..
