Author Topic: bad vibrations...... and no TDC mark on flywheel...  (Read 8482 times)
Reply #15August 24, 2011, 08:37:47 pm
  • 3468
    • McScrubbins Body Wash
Re: bad vibrations...... and no TDC mark on flywheel...
« Reply #15 on: August 24, 2011, 08:37:47 pm »
just skimmed through quickly.
Instead of taking the head off to check TDC you can take an injector out and use a long pencil (or something longer preferably) to measure TDC. When the pencil stops rising thats TDC. You can't do it by your self obviously but the theory is there.
I definitely agree that you WILL find a TDC mark. I don't think the flywheel goes on without being in the right place on the crank. there is a weird offset making it 5 bolts.
