Author Topic: Ko3 on 1.6  (Read 20127 times)
Reply #15August 12, 2011, 03:15:45 pm
Re: Ko3 on 1.6
« Reply #15 on: August 12, 2011, 03:15:45 pm »
surging is usually a barking fluttering noise, and its usually happens with too big of a turbo,  i dunno what noise ur turbo was making it was probably just some funky over spun noise haha.  i drove a tdi beetle with a burnt up vnt turbo and it sounded like a g60
oh yes.. turbo bark.. ive done that a few times.. its hard to make it bark.
Reply #16August 15, 2011, 07:44:52 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
Re: Ko3 on 1.6
« Reply #16 on: August 15, 2011, 07:44:52 pm »
i used to get the merc spec t3 on my old mk3 aaz to surge, changing up gears when at full boost and laying into the pedal again, at more than 20 psi but low rpm (like 2000).
I had a 02a ASD gearbox (very long ratios) and it wasnt the best combination for legal highways speeds, but 4th gear was great and illegal speeds were easily within reach.
a K03 sized turbo on the 1.9 is great at highways speeds for overtaking, thats what I had before the t3. On a smaller capacity engine it would be a little better I reckon, especially in a smaller car like a mk1.
'91 Golf Cabrio 1.9TD
Reply #17August 15, 2011, 08:53:39 pm
nathan_b
  • 361
Re: Ko3 on 1.6
« Reply #17 on: August 15, 2011, 08:53:39 pm »
because you are at max boost while cruising... haha
Reply #18August 16, 2011, 01:15:31 am
gldgti
  • 488
Re: Ko3 on 1.6
« Reply #18 on: August 16, 2011, 01:15:31 am »
ahh yes - if you can get a double acting wastegate actuator and rig up a vacuum solenoid to open the wastegate at low throttle settings (like the aaz in the mk3 runs standard) then you dont have to cruise around with 12psi of boost.
Reply #19August 16, 2011, 06:45:26 am
Re: Ko3 on 1.6
« Reply #19 on: August 16, 2011, 06:45:26 am »
Really what's so wrong with cruising at max boost? The turbo is still in its efficiency, and not to mention instant power. I see no downside
Reply #20August 16, 2011, 08:56:16 am
nathan_b
  • 361
Re: Ko3 on 1.6
« Reply #20 on: August 16, 2011, 08:56:16 am »
I agree, I saw a highway mpg drop when I went from a k14-6psi cruising, to a k24-3psi cruising. And with the k24 I had to drop to 4th to do major passing, while k14 would pull hard in 5th at 60mph.
Reply #21August 16, 2011, 09:05:03 am
Re: Ko3 on 1.6
« Reply #21 on: August 16, 2011, 09:05:03 am »
So basically I see the k03 being able to pull hard from like 50 in 5th up to max rpm on a 1.6. It did on my 1.9.. The 1.6 should have better use of it at higher rpms I would think. Also I would think cruising at higher boost to be better because things are still burning more efficiently.
No downside to a k03 on a 1.6 ;)
Reply #22August 16, 2011, 10:12:30 am
Re: Ko3 on 1.6
« Reply #22 on: August 16, 2011, 10:12:30 am »
PROVIDED you plan to be at 18PSI or less... :)
Reply #23August 16, 2011, 10:14:37 am
Re: Ko3 on 1.6
« Reply #23 on: August 16, 2011, 10:14:37 am »
A sustained intercooled psi of 15 with spikes to 18-20 will be within the range of the k03's ability and not decrease its life expectancy. It hauls ass on a tdi with only 12psi.. 15 and more fuel should be a rocket.
Reply #24August 17, 2011, 04:05:06 pm
gldgti
  • 488
Re: Ko3 on 1.6
« Reply #24 on: August 17, 2011, 04:05:06 pm »
there is a downside to cruising around at 12psi - its extra heat loading on the engine and extra blowby that you don't need. You'll likely see increased oil consumption.
Reply #25August 17, 2011, 04:14:05 pm
Re: Ko3 on 1.6
« Reply #25 on: August 17, 2011, 04:14:05 pm »
yea, cruising at high boost is bad..
it takes heat to make boost. and it takes fuel to make heat.
it takes me alot of pedal to be making 12 psi boost. my car only makes 3-4 psi cruising with the VNT..
12 psi boost and im accelerating, not cruising.
Reply #26August 17, 2011, 08:00:56 pm
Re: Ko3 on 1.6
« Reply #26 on: August 17, 2011, 08:00:56 pm »
Not with a k03. Your not making high boost because your dumping a *** ton of fuel in to the motor, your making high boost because a k03 is literally the size of your one hand in a fist. It is not the fact that you are moving hot air, just air to begin with.
High boost is not bad on a small turbo, it is uber efficient. If it were bad how did my tdi make it to 430,000kms constantly cruising at full boost? And make 50+ mpg while doing so??  :P
Reply #27August 17, 2011, 08:24:33 pm
nathan_b
  • 361
Re: Ko3 on 1.6
« Reply #27 on: August 17, 2011, 08:24:33 pm »
Yeah, you can't compare with a vnt, because you aint got no wastegate. Cruising on the highway, with the load of speed, the energy is there. turn it into boost and become more efficient, or dump it out the tailpipe.
My truck got much better mpgs with a small turbo and higher boost on the highway, than it did with a larger turbo and less boost. Nothing else changed on the motor, so, there is no way my motor became more efficient and got worse mpg. Put a t3 on a mk3 ahu/1z and tell me it is more efficient. ..
it's not
Reply #28August 18, 2011, 04:27:23 am
Re: Ko3 on 1.6
« Reply #28 on: August 18, 2011, 04:27:23 am »
To get the same efficiency out of a T3 you'd have to be burning alot more fuel to make the "hot" air to spool it. Don't forget that a k03 is at full boost of 12-13psi at 1900rpm, cruising at 2500 easy on the pedal probably has the motor at the same area boost wise.
A properly working VNT on the TDI it came on has the motor at higher boost levels than you think. They switched to the VNT so that the motor could have higher boost literally anytime it wanted it.
Reply #29August 18, 2011, 03:55:00 pm
gldgti
  • 488
Re: Ko3 on 1.6
« Reply #29 on: August 18, 2011, 03:55:00 pm »
it's not
actually, I got better fuel economy out of my aaz mk3 with a t3 than I did with the stock t2 (which is same size as the k03). not the vw 1.6 spec t3 though, the merc spec t3 which has a much larger compressor.
I'm taking an average over ~40,000km (12 months driivng) of 5.7l/100km for the stock turbo and 5.4l/100km for the T3.
