Author Topic: 1.9 head porting pictures anyone?  (Read 19266 times)
Reply #15August 13, 2011, 04:21:42 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
Re: 1.9 head porting pictures anyone?
« Reply #15 on: August 13, 2011, 04:21:42 pm »
well hopefully the lack of overlap with this stock cammed 1.9 wont cause me any probs :-)
so got busy today
carbide rotary burr tool....
The 1Y block - king of versatility it would seem :-)
'91 Golf Cabrio 1.9TD
Reply #16August 13, 2011, 05:42:40 pm
« Reply #16 on: August 13, 2011, 05:42:40 pm »
Looks pretty good. I'd probably pull the exhaust studs and give that area a nice sanding.
Are you rebuilding the head or just freshening it up?
Reply #17August 13, 2011, 06:08:53 pm
Syncroincity
  • 727
« Reply #17 on: August 13, 2011, 06:08:53 pm »
About the same here. I didn't port match, just opened up the head around the valves and ports. Just feel around with your finger, you'll know immediately where to take off material.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #18August 14, 2011, 12:10:54 am
gldgti
  • 488
« Reply #18 on: August 14, 2011, 12:10:54 am »
just a freshen up really - the engine was a sort-of-freebie, complete but had come from the UK to australia and had been left out in the weather a bit - inside it was all choked up with black gunked up old engine oil, so this has really been a process of take everything apart and clean it (to make sure the oilways arent blocked) and put back together.
I've reassembled the head today with a set of new lifters and I hand lapped the valves in but apart from that and hte mild port job its just going back together - measured the valve guide wear - well within tolerances on the intake and still reasonable on the exhaust, and the rest of it all looks pretty good.
the block is in much the same state internally - black gunk everywhere.... anyone got any advice for easily cleaning it?
Reply #19August 14, 2011, 06:39:46 am
« Reply #19 on: August 14, 2011, 06:39:46 am »
just a quick jobbie that will help a lot, i think the most important part of this the valve seat/bowl area, they're really not shaped well there.
