Author Topic: Veg injection service?  (Read 5392 times)
July 26, 2011, 07:50:55 am
dieselherb1
  • 354
« on: July 26, 2011, 07:50:55 am »
Anyone used Veg injection Service nozzles? Where are they made?
Reply #1July 26, 2011, 03:12:06 pm
410
  • 581
Re: Veg injection service?
« Reply #1 on: July 26, 2011, 03:12:06 pm »
I've used the .216 ones.  They are made in China but I found them to work nicely.  I had bought a set of .205 from prothe and they were not as good.
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles.  Sold!
Reply #2July 27, 2011, 06:44:24 am
BigVWman
  • 332
« Reply #2 on: July 27, 2011, 06:44:24 am »
I also used the .216 from veg and was very impressed.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #3July 30, 2011, 07:17:01 am
dieselherb1
  • 354
« Reply #3 on: July 30, 2011, 07:17:01 am »
I tried a set from Prothe, ran 5000-7000 miles removed had them pop tested only 2 were marginal. I didn't get to witness the spray pattern. Veg Service won't reply to my question where are these made.
Reply #4July 30, 2011, 07:30:48 pm
catlin_cava
  • 1954
« Reply #4 on: July 30, 2011, 07:30:48 pm »
When it came to injectors I called performance diesel injection and had them build me Bosch injectors with .216 nozzles and I'm very impressed with them. I recommend them to anyone that's looking for an upgrade,
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #5August 01, 2011, 08:05:04 am
BigVWman
  • 332
« Reply #5 on: August 01, 2011, 08:05:04 am »
Even some of the bosch nozzles have questionable patterns,pressures and origins! If you go with a service at least you get the company standing behind their end product, but personally, i'm too cheap to do that and so long as the veg nozzles tested well i was happy, i had read previously all veg would say is the guidelines/controls under which they are manufactured. It lends you to draw your own conclusions but suspect Chinese origin.The nozzles themselves merely say veg injection service. I have to believe with some of the positive reviews i have read here on veg/smog that they are of better quality/durability than prothe!
Tim
Reply #6August 03, 2011, 06:17:41 am
dieselherb1
  • 354
« Reply #6 on: August 03, 2011, 06:17:41 am »
There is a company on Ebay, calls itself dieselland performance USA. They say the nozzles they sell are made in their factory. Also they is a guy of EbayUK whos sells nozzles, he said they're made "in the states". Wondering same company? Also alot of discussion on calibrate or not(TDI injections) Spoke to a TDI Guru, he said as long as first pressure is 3000psi second should be okay? If not?
