Author Topic: 1.6 Flywheel  (Read 5241 times)
July 14, 2011, 08:31:32 am
silentdub
  • 135
1.6 Flywheel
« on: July 14, 2011, 08:31:32 am »
how heavy is the OEM flywheel?
Is there a cheap light weight replacement or should I just send this off the the machine shop for a diet?
Reply #1July 14, 2011, 09:20:00 am
Re: 1.6 Flywheel
« Reply #1 on: July 14, 2011, 09:20:00 am »
gasser flywheel is lighter than a diesel wheel, use that.. but be sure to use one that has a TDC mark, or mark it for TDC.
lightened flywheel is too light.. they take a gasser flywheel (witch is already way lighter than the diesel flywheel, and lighten it some more)
Reply #2July 14, 2011, 09:26:00 am
DieselBalz
  • 301
Re: 1.6 Flywheel
« Reply #2 on: July 14, 2011, 09:26:00 am »
http://www.vwdiesel.net/forum/index.php?topic=29283.msg252630#msg252630
See that thread we just had a big discussion on flywheels.
Reply #3July 14, 2011, 09:31:36 am
Re: 1.6 Flywheel
« Reply #3 on: July 14, 2011, 09:31:36 am »
theres already enough info for the OP right there..
its more just some bickering, and personal preferences in that other thread..
Reply #4July 14, 2011, 09:52:26 am
silentdub
  • 135
Re: 1.6 Flywheel
« Reply #4 on: July 14, 2011, 09:52:26 am »
So just use an 8V flywheel then? I'll see if I can find one, otherwise, I can just take a few lbs off this one.
I'm going to waterfest this weekend, so maybe I'll find some stuff.
Reply #5July 14, 2011, 10:03:50 am
Re: 1.6 Flywheel
« Reply #5 on: July 14, 2011, 10:03:50 am »
what clutch/flywheel do you have right now? if you can get a clutch, flywheel, and pressure plate off a 1.8 8v engine, then it will be an upgraded clutch, and a lighter flywheel.. even better than that would be 16v pressure plate.. better holding power.
8v or 16v 210mm flywheel
8v or 16v 210mm pressure plate
8v 210mm clutch disk..
Reply #6July 14, 2011, 10:25:22 am
silentdub
  • 135
Re: 1.6 Flywheel
« Reply #6 on: July 14, 2011, 10:25:22 am »
Thanks man, that clears things up. I'll see what I can find at the swap meet.
Reply #7July 14, 2011, 10:27:35 am
Re: 1.6 Flywheel
« Reply #7 on: July 14, 2011, 10:27:35 am »
just be sure that whatever flywheel you get, has 9 holes around the edge, to bolt it to the pressure plate..
Reply #8July 14, 2011, 11:05:36 am
silentdub
  • 135
Re: 1.6 Flywheel
« Reply #8 on: July 14, 2011, 11:05:36 am »
I'll keep that in mind.
Should I assume that a 210mm are not all the same? I am not sure why some would have 9 holes and others less.
Reply #9July 14, 2011, 11:10:44 am
Re: 1.6 Flywheel
« Reply #9 on: July 14, 2011, 11:10:44 am »
no, only the 210mm wheels got 9 bolt holes.. all the others have 6 bolt holes (200mm and 190mm)
Reply #10July 14, 2011, 11:40:57 am
silentdub
  • 135
Re: 1.6 Flywheel
« Reply #10 on: July 14, 2011, 11:40:57 am »
Perfect! Thanks man.
9 holes = 210MM
Outstanding.
Reply #11July 14, 2011, 11:59:19 am
DieselBalz
  • 301
Re: 1.6 Flywheel
« Reply #11 on: July 14, 2011, 11:59:19 am »
Yeah but there was some good info that you shared as well. Its worth a read through.
Reply #12July 14, 2011, 12:28:07 pm
silentdub
  • 135
Re: 1.6 Flywheel
« Reply #12 on: July 14, 2011, 12:28:07 pm »
I read through it and noted that the 1,6 is a 200mm flywheel, I assume as long as you change the pressure plate and clutch, the 210mm will bolt up and work fine?
Reply #13July 14, 2011, 02:34:42 pm
DieselBalz
  • 301
Re: 1.6 Flywheel
« Reply #13 on: July 14, 2011, 02:34:42 pm »
No problema sir. I ordered the 210mm kit from bfi with the lw fw, bolted right up. Make sure you get new pp and fw bolts as well. I got those from gap. They have a kit that comes with the bolts and the throw out bearing and cover.
Reply #14July 15, 2011, 10:27:55 am
Re: 1.6 Flywheel
« Reply #14 on: July 15, 2011, 10:27:55 am »
to upgrade, to 210mm setup, you need to change (atleast) the clutch disk, flywheel, pressure plate. thats at a bare minimum..
what i did, was pulled the brand new clutch off my 1.8 gasser, and bolted the whole setup on my diesel. then i lost my timing mark, and had to make a new one..
if you get a used setup, then try and get it off a late mk1 1.8, or an early mk2 1.8, they have timing marks on them.
200mm parts and 210mm parts are in no way interchangeable..
