Author Topic: Internal IP pressure specs  (Read 15100 times)
Reply #15October 11, 2011, 06:56:14 am
92EcoDiesel Jetta
Re: Internal IP pressure specs
« Reply #15 on: October 11, 2011, 06:56:14 am »
There seems to be various numbers thrown around as to what the internal IP pressure should be. Does anyone have the official Bosch spec for it?
So far, I have a gauge hooked up to the out bolt pedestal and I have 2 regulator bolts to play with. They both measured 30 psi at idle of around 1000 rpm. I pulled both regulator bolts out and replaced the o-rings on both of them and installed only one so far and noted the pressure is now 20 psi (from re-newing the o-rings). I tapped on the regulator bolt while the engine is idling while watching the gauge and got it up to 50 psi at 1000 rpm. I have to take on for a road test.
Reply #16October 11, 2011, 09:02:05 am
Mark(The Miser)UK
  • 1557
« Reply #16 on: October 11, 2011, 09:02:05 am »
Who's throwing numbers around? Never seen Bosch numbers. They are hidden in their microfische and unobtainium.
Apart from Hagar's claimed figures for the 107A, the most accurate, and based on 23 TD pumps averaged, is the scatter diagram fig 46, on the SAE paper  #820441 about the 1.6TD design.
My figures are the best anywhere in the public domain. Period!
I averaged the scatter diagram to create a reference plot to compare and contrast, Hagar's corrected figures, 'My pump' and someone called Levi's...  Do a search...
Mark-The-Miser-UK
Reply #17October 11, 2011, 11:47:54 am
« Reply #17 on: October 11, 2011, 11:47:54 am »
Forgot about this thread, I thought I had something about this already.
Tried starting again last night, temp slightly below freezing. It was a no go, fired quite a bit but couldn't get spinning.......even blew some perfect smoke rings haha ;D. Battery's charging now.
Reply #18October 11, 2011, 02:13:47 pm
92EcoDiesel Jetta
« Reply #18 on: October 11, 2011, 02:13:47 pm »
Thanks good to know. I've been looking for the tool to fine-adjust it, but most diesel shops don't have it, or only sell it as part of a master kit that costs close to a grand. No thanks.
I just need that tool, and a good computerized advance tach timing light. I've got the piezo pickup transducer already. I'm kinda pumped to try all this, because my MPG blows (38 in a Rabbit Pickup). If I can get it to 43+, I'd be happy. Rebuilt the pump myself, but obviously, it needs calibration.
There's a lip at the bottom of the regulator bolt's head where you can make a tool to hook onto that lip like a "puller", by advancing the puller screw. you can fine adjust the pressure. However, with a long punch and a hammer and watching the gauge while the engine is idling tapping on the center of the bolt, you have pretty good control increasing the pressure by tapping with a hammer. At least that was my expereince using a hammer and and 10" extension on a 3/8 drive allen head driver bit as the punch.
Reply #19October 11, 2011, 03:34:23 pm
Powered by Spearco
  • 1203
« Reply #19 on: October 11, 2011, 03:34:23 pm »
Does any one remember this info and would it help?
http://www.vwdiesel.net/forum/index.php?topic=19692.0.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #20October 11, 2011, 03:34:44 pm
Mark(The Miser)UK
  • 1557
« Reply #20 on: October 11, 2011, 03:34:44 pm »
That seems a good method.
 Possibly a better one is simply a M5 or M6 bolt with a nut on it as a depth gauge/depth stop, when used as a punch...
Mark-The-Miser-UK
Reply #21October 11, 2011, 03:52:24 pm
Mark(The Miser)UK
  • 1557
« Reply #21 on: October 11, 2011, 03:52:24 pm »
Funny thing that, I already had it rotated on my screen earlier on ACDSEE.
Not easy to decypher.
How does the measured internal pressure  have a range of values and not a single figure for each rpm reading? Or is this not a client's particular results, but the general spec? :-\ I'll give it a good read again.
Mark-The-Miser-UK
Reply #22October 11, 2011, 05:07:42 pm
92EcoDiesel Jetta
« Reply #22 on: October 11, 2011, 05:07:42 pm »
I called a diesel injection shop and asked what the internal pump pressure should be for my pump 0 460 484 027 and was given these numbers:
5 to 5.5 bars (72.5 to 79.7 psi) @ 2500 RPM (engine ). This translates to 32 psi at 1000 rpm (assuming pressure is linear), which was what my regulator was at before I started messing with it!
« Last Edit: October 12, 2011, 06:47:23 am by 92EcoDiesel Jetta »
Reply #23October 11, 2011, 06:56:34 pm
Mark(The Miser)UK
  • 1557
« Reply #23 on: October 11, 2011, 06:56:34 pm »
The data on the spec sheet for  the pump pressure nestles directly below the SAE real pump averages. Smack on where I changed  my pressures to.
Note the impossibility of following Hagar's 107A values, by his 'Desciples'
The SAE paper dates from a little after 1981.
 Funny how Bosch specs for this pump dropped the internal pressure a few psi, compared to the SAE average  of 23 contemporary pumps.
Here is my graph again for reference:
Mark-The-Miser-UK
Reply #24October 11, 2011, 07:25:11 pm
  • Online
« Reply #24 on: October 11, 2011, 07:25:11 pm »
Looking at these idle and 2500 RPM numbers makes me think mine might be a tad high and that may explain the little bit o marble sound I have at just off idle.  I have gone to watching the psi of the IP gauge as kind of a shift light.  Mine doesn't have one but it seems that when i hit 75 lbs of pressure the shift is just about right on the level surface.  Going to run it that way for a bit and see what the mileage does.
Reply #25October 11, 2011, 07:49:36 pm
Mark(The Miser)UK
  • 1557
« Reply #25 on: October 11, 2011, 07:49:36 pm »
Note that Levi was 'on the money' with his second iteration, but went on to excessive pressures in a mistaken belief [like many] that the 107A pump was the standard spec to aim for.
Also note my pump was right down the bottom of the graph when I first checked it, yet it operated linearly. With the right soft spring we could all operate down there and the leaking pump seals would be a thing of the past...
Mark-The-Miser-UK
Reply #26October 11, 2011, 09:19:01 pm
  • Online
« Reply #26 on: October 11, 2011, 09:19:01 pm »
I did notice that my engine ran fine with a bit of advance with the gauge showing 10 lbs.  I think on revving it up the pressure only topped out at 25.  So yes it will run but I wonder how well?  Yours pull OK under a hard load?  Mileage acceptable?
I think the pressure could be a little less than the oft quoted 43 lbs at idle but just how much less we shall see.  I knocked mine back and am watching for changes to the overall performance.  Mileage is one thing, drivability is another.  I can't be in everyone's way getting 60 MPG.
Reply #27October 12, 2011, 06:55:35 am
92EcoDiesel Jetta
« Reply #27 on: October 12, 2011, 06:55:35 am »
Is this the pump spec sheet (below pic) you're referring to? If I'm understanding correctly, that is a spec for settings of a Bosch test stand for one particular injection pump. Does anyone know which pump that spec sheet is for? Internal pump pressure is not the same on all VE pumps from what I was told.
« Last Edit: October 12, 2011, 07:02:15 am by 92EcoDiesel Jetta »
Reply #28October 12, 2011, 12:10:06 pm
mtrans
  • 308
« Reply #28 on: October 12, 2011, 12:10:06 pm »
My figures are the best anywhere in the public domain. Period![/color]
Mark I DO belive you.
I`ll improve my English
Reply #29October 12, 2011, 02:50:01 pm
Mark(The Miser)UK
  • 1557
« Reply #29 on: October 12, 2011, 02:50:01 pm »
:o
I've  just chased those numbers on that Bosch paper literally all round Eastern Europe, Europe and back to America, where I found they translate into a 1984 1.6TD ... Jetta.  Thus I was correct, Bosch did lower the internal pressure  of the pump from the first 1.6TD's
This shows the truth being, that  Bosch, just like  lots of other Co's were experimenting and learning as they went along...
A big question:
How long does it take for a pump to fill a piston chamber, and does vaccuum play more part than pressure?
Mark-The-Miser-UK
