Author Topic: engine vibration problem  (Read 12743 times)
Reply #15June 15, 2011, 10:01:07 am
Re: engine vibration problem
« Reply #15 on: June 15, 2011, 10:01:07 am »
also, if your idle speed is too low, the engine will shake like theres no tomorrow, even a good running engine..
Reply #16June 15, 2011, 11:25:09 am
vako
  • 187
« Reply #16 on: June 15, 2011, 11:25:09 am »
I have the VW 1.9TD-M in my 4 door suzuki sidekick .. It's been converted for 4 yrs now .. I have to tell you I use the ACME install kit , and there is no such vibrations your talking of ... I have the original harmonic balancer removed too , running the V-belt set up from the older VW 1.6 , so I feel that is not your trouble .... ;)
I too am using the suzuki sidekick engine mounts with the diesel  , and many have with out the issue of vibration  .. That being said , I think they could still cause your trouble !!  Here is why  :
The suzuki mounts as you are aware are made in such a manner that the outer metal housing will go down and bottom out against itself if the mount is worn or soft from extended use .. You must also remember the diesel engine as much more torque than the gas , so if the mounts are worn or  soft this problem would not of shown itself until the diesel was installed , and the torgue was applied to them .. In other words , the diesel engine could be  causing the worn mounts to bottom out .. :o .
I would try a NEW set of suzuki engine mounts , to at least rule out this problem  .. Also the mounts from the later suzuki sidekicks are about 1/2"  higher , due to the fact they have more rubber in them . These would be the best to try ............
Just my two sense worth ....................... N-Z  :)
  hello thanks for your attention.   first of all the info about using the engine without harmonic balancer was very usefull mfor me. i wi9ll ot have to buy one to test it  8)
  now about the mount. i have 1 mount from late vitara (big one) and the other from my vitara (smaller one) both are in very good condition and work perfectly, no vibration is felt on the body. i am familliar with engine mount vibration  and i can say that it is a different beast  ;D in my case it vibrates like mobile phone vibration alert , but it has higher frequency
. i dont even feel it on the body, it is most of all felt on accelerator pedal and gear lever (when accelerating in gear)
  no, on idle it is quite smooth and revs are somewhere between 700-900.
 last two days i have noticed that accelerator pedal starts to also starts vibrate lightly at about 2000, then it goes away. and when i reach 3500 it starts again but now vibration is way much stronger and it continues until about 4000rpm. the vibration is accompanied with strange vibration sound coming from an engine. and foam appiers in return line  :( it is impossible to hold revs in that range. it feels that something is gonna fall off if you don't take the foot of the accelerator.
  it happens when it is in gear or in neutral. as as i remember it also vibrates off the throttle. doesn't matter if the clutch is depressed or not.
 can faulty and worn out injectors or injectionpump cause that problem?
 i have balanced the flywheel so imbalance is excluded.
 i'm afraid not to damage something... :-X
Reply #17June 15, 2011, 11:46:43 am
« Reply #17 on: June 15, 2011, 11:46:43 am »
I think the foam in the return line is a big clue.  It can only really be caused by air getting in to the system somehow.
I'm far from an expert here but I'm going to go out on a limb and suggest the pump shaft seal may be on its way out.  Since it is right in front of the vane pump, it sees negative pressure (suction) when the injection pump is operating.  The higher the RPMs, the more suction it would see.  Perhaps at higher RPMs it is letting some air get in, which would cause your timing to go bananas and would definitely cause some weird running issues + foam in the outlet line.
I am assuming you have a clear inlet line and you don't see any air on the inlet side, correct?
The rest of the pump body is under pressure, so fuel would leak out rather than air getting in.
Reply #18June 15, 2011, 01:31:18 pm
vako
  • 187
« Reply #18 on: June 15, 2011, 01:31:18 pm »
thank you very much  :D your post was really helpful and i think your right about the front seal
i have no clear inlet line but it does the same even if i feed fuel from a bottle straight to the pump.     and i have noticed that front front lower side of the pump is always wet. it means that there is a small leak there  :( sometimes at full throttle lda hole squirts out some fuel too , i don't get how it is related to the pump internal pressure anyway :D
   as i can see my pump needs resealing. :(
i hope that injectors are good because car idles well and it does not smoke excessively.
i will visit diesel specialist and if he tells me the same i will order reseal kit
« Last Edit: June 15, 2011, 01:33:53 pm by vako »
Reply #19June 17, 2011, 05:03:22 am
vako
  • 187
« Reply #19 on: June 17, 2011, 05:03:22 am »
today i have visited diesel specialist :D and now the problem is solved :D it seemed to bo loose rear mount of the ip pump. so at certain rpm it resonated vigirously. now my engine is almost as smooth as petrol engine :D and i can easily rev to 5000  ;D
Reply #20June 18, 2011, 03:15:30 am
newfie-zuk
  • 2
« Reply #20 on: June 18, 2011, 03:15:30 am »
Excellent ! ;D  I am glade you got it solved ..
Cheers ........... :)
Reply #21June 22, 2011, 10:29:44 am
« Reply #21 on: June 22, 2011, 10:29:44 am »
Yeah, any wetness on the pump will be bad in the long run.  Glad you solved your immediate issue though!!
Definitely deal with the leaks as soon as you can.  They will only get worse!!  The LDA one is definitely a more difficult seal to do, and if not fixed can result in the diesel eating the LDA diaphragm too.
Reply #22June 22, 2011, 01:57:32 pm
vako
  • 187
« Reply #22 on: June 22, 2011, 01:57:32 pm »
after the fix i have not noticed any more wetness or fueb being spayed out of the lda :D i think abnormal vibration was causing the leaks :D Thank you for your reply i will pay attention to wetness on the pump ;D
