Author Topic: FS: MK1/MK2 diesel turbo swap  (Read 11416 times)
Reply #15May 17, 2011, 05:51:46 am
Rhetoric
  • 12
Re: FS: MK1/MK2 diesel turbo swap
« Reply #15 on: May 17, 2011, 05:51:46 am »
you are aware that shipping will be at least $100, right
Definitely. I have no issue paying it.
Reply #16May 17, 2011, 08:33:33 am
« Reply #16 on: May 17, 2011, 08:33:33 am »
i believe he was talking about shipping for the turbo..
the whole engine would be 4-500 bucks to ship i imagine..
Reply #17May 17, 2011, 12:44:40 pm
rwdriver
  • 107
« Reply #17 on: May 17, 2011, 12:44:40 pm »
ok, so I got a couple shipping quotes, and it's gonna be about $150 to ship (it weighs 80lb)
$500 usd shipped anywhere in the lower 48
And I will only include one airbox (whichever one you want)
first one to PM me gets it
« Last Edit: May 20, 2011, 02:27:51 pm by rwdriver »
Reply #18May 20, 2011, 08:03:48 am
rwdriver
  • 107
« Reply #18 on: May 20, 2011, 08:03:48 am »
still for sale
Reply #19May 21, 2011, 06:27:53 pm
trav1856
  • 230
« Reply #19 on: May 21, 2011, 06:27:53 pm »
I'm pretty sure we all are. Luckily, however, I found a quantum that has a 1.6 TD in it, so I think I might just buy it. Thanks all the same.
1981 Rabbit Diesel
1981 Cabriolet
Reply #20May 21, 2011, 08:19:02 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #20 on: May 21, 2011, 08:19:02 pm »
Yeah right... 80 Lbs. cost $500 Crazy ::)
I just shipped a 020 transmission from maine to North Carolina for $75
Grayhound  ;)
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #21May 22, 2011, 07:14:20 pm
rwdriver
  • 107
« Reply #21 on: May 22, 2011, 07:14:20 pm »
still for sale :)
Reply #22May 27, 2011, 01:41:02 am
damac
  • 531
« Reply #22 on: May 27, 2011, 01:41:02 am »
Are these parts that just came off working cars?
Or is there any known rebuild history on the turbo and injection pump?
I wonder what turbo would suit my jetta better which has a t3.
1985 turbo diesel jetta
Reply #23May 30, 2011, 07:12:23 am
« Reply #23 on: May 30, 2011, 07:12:23 am »
K24 and T3 are basically identical, there isnt really a BETTER turbo out of those 2, they are about exactly the same. sunno if you would notice a difference even, going from a T3 to a K24..
Reply #24June 03, 2011, 08:37:42 pm
damac
  • 531
« Reply #24 on: June 03, 2011, 08:37:42 pm »
With my tranny and the stock tires I believe I am around 3000 rpm on the tach @ 70mph on the freeway which is where the car mostly gets driven.  I don't have a problem with the way the car acts in gears 1-4, you can go crazy with the pedal if needed but otherwise cruise around nicely compared to my little compact gas ford :)
But in fifth gear  at 70mph the car pretty much needs to be on flat ground for me to stomp on the pedal, car ramps up, then speeds off and starts pulling in higher rpms.  Wasn't sure if that could be helped by a different turbo or not since the fifth gear experience is different than the others.
I have barely kept the car at 65mph with a couple people in it going up a moderate long hill, but it just stays put and won't pull any better in fifth gear.  Not a big deal but if I could do something about it I would :)
Reply #25July 16, 2011, 09:12:39 pm
rwdriver
  • 107
« Reply #25 on: July 16, 2011, 09:12:39 pm »
SOLD
And I highly reccomend going with a smaller turbo on a 1.6 td. with the k24, boost starts to rise at about 3000rpm, but with the k03, it starts around 1400rpm. IMO, the k24 is too big for a 1.6. I have driven the same car with both turbos, and I much prefer the smaller one. Even though the max boost output of the smaller turbos is limited, the increase in driveability makes it worth it IMO. My k03 puts out 18psi, which is plenty for me.
