Author Topic: I was about to go on a drive, when I noticed...  (Read 4523 times)
May 01, 2011, 12:32:02 pm
gabo
  • 26
« on: May 01, 2011, 12:32:02 pm »
... A large kink in my hood. I figured some hoodlums had jumped on it in protest to my Montreal Canadiens Flag. I opened my hood just to be sure and it nealry srpung into my face. The cause? This:
Now I think I'll have to turn it into a cube, minus the engine and wheels I'm keeping. Any suggestions? Keep in mind I'm a tig welder / fabricator by day.
'93 Passat GL AAZ Calypso blue!
Reply #1May 01, 2011, 12:53:36 pm
bvolks73
  • 183
Re: I was about to go on a drive, when I noticed...
« Reply #1 on: May 01, 2011, 12:53:36 pm »
 :o
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #2May 01, 2011, 01:10:11 pm
J Z
  • 42
    Sweden
« Reply #2 on: May 01, 2011, 01:10:11 pm »
Well-- Thats one way to lowering a car...  :P
I think you will be able to fix this. Jack up the car and it should sink down to where it's supposed to be.  If the lower part is rusted out, you can weld a new outer skin on it.
It won't be pretty tho... ;)
I did the same in the rear of an Golf 2 and it's been that way for 3 years now..
(sorry for any misspellings)
« Last Edit: May 01, 2011, 02:44:33 pm by J Z »
'75 Volvo 242 D24 TIC
'90 Golf II 1,9 GTD
'91 Golf II 1,9 M-TDI
Reply #3May 01, 2011, 01:31:08 pm
rallydiesel
  • 1880
« Reply #3 on: May 01, 2011, 01:31:08 pm »
A guy on the vortex welded the front half of a Caddy back together because of strut tower rust. Of course, Caddy's are harder to come by but it can be done. If you are a welder then it's easy peasy. The Caddy guy had never done any welding before tackling such a huge job and it turned out awesome.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4May 01, 2011, 02:47:28 pm
« Reply #4 on: May 01, 2011, 02:47:28 pm »
u could fix it, but its much simpler to move on to a new shell
Reply #5May 01, 2011, 03:12:17 pm
« Reply #5 on: May 01, 2011, 03:12:17 pm »
Depending on how easy it is to find a good replacement I would probably go that route. Of course, the cost of having the "new" vehicle safetied is another issue
Reply #6May 02, 2011, 01:19:15 am
« Reply #6 on: May 02, 2011, 01:19:15 am »
Tube Frame :D
Reply #7May 02, 2011, 03:13:56 am
Patrick
  • 1034
« Reply #7 on: May 02, 2011, 03:13:56 am »
Must be the paint colour. Here's mine the back of mine from a month ago.
http://s1138.photobucket.com/albums/n527/patrickwbates/?action=view&current=IMG_3292.jpg#!oZZ13QQcurrentZZhttp%3A%2F%2Fs1138.photobucket.com%2Falbums%2Fn527%2Fpatrickwbates%2F%3Faction%3Dview%26current%3DIMG_3226.jpg
I chose to repower another shell rather than repair it, car was getting tough all the way around.
Reply #8May 04, 2011, 10:51:34 am
gabo
  • 26
« Reply #8 on: May 04, 2011, 10:51:34 am »
The remainder of the body looks good, the 3 other strut towers are solid.
I was just atarting to get used to the colour too!
I was thinking about making some crazy tube framed contraption! It's not too far from my line of work!
Reply #9May 04, 2011, 10:56:32 am
« Reply #9 on: May 04, 2011, 10:56:32 am »
weld that tower back on, or weld in a fresh tower.. if theres enough metal left to work with..
if you do a tube frame, you should lift it, and put some samruai running gear under it with some 30" tires or so.. 8)
Reply #10May 05, 2011, 10:35:58 am
« Reply #10 on: May 05, 2011, 10:35:58 am »
I think you can still get new towers....  could be wrong though.  It's a pretty common issue.
