Author Topic: Tearing down the Cabriolet  (Read 7063 times)
Reply #15April 18, 2011, 10:10:42 am
Re: Tearing down the Cabriolet
« Reply #15 on: April 18, 2011, 10:10:42 am »
Another point worth noting on the smaller exhausts on the diesels was also because they were never really meant to be rev'd more than 3500 from factory.. No need to have such a big intake or exhaust to move so much air if it didn't need too..
However I think a 3" exhaust and 3" intake tubing, as well as the Governor Mod in my signature.. Will liven this little beast up to intense proportions!
Reply #16April 18, 2011, 10:13:29 am
maxfax
  • 2126
« Reply #16 on: April 18, 2011, 10:13:29 am »
a 3" exhaust
Leave some money in the budget for hearing aides.....   ;D
Reply #17April 18, 2011, 10:56:29 am
« Reply #17 on: April 18, 2011, 10:56:29 am »
Use the earplugs those competition sound guys use ;). Got it all figured out.
Reply #18April 18, 2011, 11:25:09 am
« Reply #18 on: April 18, 2011, 11:25:09 am »
theres no reason to run a 3" system if the turbo motors dont even benefit from a full 3" system, over a full 2.5" system..
i wouldnt think you would need more than a 2" system on a n/a.. theres just no reason to run an over kill exhaust system. 3" is hard to fit under the car anyways.. alot harder to fit than a 2.5" system..
Reply #19April 18, 2011, 01:03:07 pm
trav1856
  • 230
« Reply #19 on: April 18, 2011, 01:03:07 pm »
Damn 'Murricans indeed Vanagon..  I had convinced a customer to put 2" pipe on his Jetta Coupe..  We actually used a decent muffler and the damned thing was still rather loud, but darn did that bugger run and sound good... It was too loud for his tastes unfortunately..  The addition of a resonator made it tolerable but at a noticeable loss of power..
if you add 3" or larger piping to your air box, instead of the 1.5" snorkel its got, that will help more than a different intake manifold..
Right on!!!  Plumb it right up beside the radiator beside the grill and you'll have faux ram air!  However you'll want to not do that in very cold temps...
so maybe a switchable air intake feed? Pull a cable....bam...no air from the psuedo-ram. Instead it gets it from inside the engine compartment. In fact I think you'd be able to use a cable-activated gasser exhaust dump (something like this: http://img216.exs.cx/img216/2440/dsc018211ym.jpg)
« Last Edit: April 18, 2011, 01:17:59 pm by trav1856 »
1981 Rabbit Diesel
1981 Cabriolet
Reply #20April 18, 2011, 03:24:41 pm
« Reply #20 on: April 18, 2011, 03:24:41 pm »
Trav! I dig the hell out of that idea. Pull it right near the manifolds, for a little warmer air when its super duper cold out, and blam cold air when you want it ;)
I agree the 3" would be overkill. 2.25 is more than enough.
Reply #21April 18, 2011, 03:29:51 pm
trav1856
  • 230
« Reply #21 on: April 18, 2011, 03:29:51 pm »
I'm please you approve, I thought it would be a good idea, but wasn't entirely sure.
1981 Rabbit Diesel
1981 Cabriolet
Reply #22April 18, 2011, 10:30:13 pm
maxfax
  • 2126
« Reply #22 on: April 18, 2011, 10:30:13 pm »
That would work pretty slick..   If you frequent bone yards check out some air cleaner snorkels on some older stuff.. They basically did the same thing back in the day except they used hot air off the exhaust to aid in warm up..   Usually they worked off vacuum, but some used a bimetal spring..  Might be able to snag one cheap..
Reply #23April 19, 2011, 10:31:45 am
« Reply #23 on: April 19, 2011, 10:31:45 am »
open up the air box on a mk2 VW. all of them had the flap for if it was too cold..
they sucked air off the exhaust manifold when it was super cold outside. then when the air warmed up enough, the box would switch from hot manifold air, to cool fender well air..
Reply #24April 19, 2011, 12:11:06 pm
trav1856
  • 230
« Reply #24 on: April 19, 2011, 12:11:06 pm »
Speaking of Hot and Cold.
I've got a knob on the right hand side of my steering wheel that looks like a choke cable (but we all know it's not), is this the cold start cable? (and what does it do?)..advances the timing or something?
1981 Rabbit Diesel
1981 Cabriolet
Reply #25April 19, 2011, 12:59:30 pm
« Reply #25 on: April 19, 2011, 12:59:30 pm »
yes, cold start advance..
Reply #26April 19, 2011, 01:49:01 pm
trav1856
  • 230
« Reply #26 on: April 19, 2011, 01:49:01 pm »
I love you, man
1981 Rabbit Diesel
1981 Cabriolet
Reply #27April 19, 2011, 08:44:48 pm
« Reply #27 on: April 19, 2011, 08:44:48 pm »
the ", man" in the i love you sentence is what takes that phrase from being awkward.. to socially acceptable. ;)
Pulling the cold start advance lever mechanically advances the piston inside the pump by about 0.05mm (i think) if you were to use a dial indicator and pull the lever out. Generally with a stock setting of around 0.90mm the advance to 0.95mm really helps a ton for cold starting and warm-up. However with todays advanced power settings of 1.00mm and up, the coldstart lever is rendered pretty much useless.. unless you have an mk2 pump which should also have an idle increase on it as well when you pull the lever :)
Reply #28April 19, 2011, 10:52:15 pm
trav1856
  • 230
« Reply #28 on: April 19, 2011, 10:52:15 pm »
So if I do the governor mod and set it to 1.0mm, I wouldn't need the advance? Gotcha. Now the other question is, this plunger thing, I keep hearing people say put a bigger plunger and a 1.9 cam plate. Necessary?
1981 Rabbit Diesel
1981 Cabriolet
Reply #29April 20, 2011, 01:15:30 am
maxfax
  • 2126
« Reply #29 on: April 20, 2011, 01:15:30 am »
Not without a turbo......
