Author Topic: new clutch time soon..i believe. can I use the manual adjust cable?  (Read 6294 times)
Reply #15April 20, 2011, 08:16:09 am
Re: new clutch time soon..i believe. can I use the manual adjust cable?
« Reply #15 on: April 20, 2011, 08:16:09 am »
I like clutchnet.com  Some gave it a bad rap for the rod drilling holes into the cover, but those same guys would never answer me if they replaced the rod or used the old one. If the rod isn't cone shaped anymore the beefy clutches will take advantage. I have 15,000 miles on mine no issues at all.
Reply #16April 20, 2011, 10:35:18 am
« Reply #16 on: April 20, 2011, 10:35:18 am »
sachs usually sells pretty good stuff.
if you need a good stock type clutch, and you have a 210mm flywheel laying around, you can change your clutch, and do an upgrade at the same time.. should have a 200mm clutch, pressure plate, and flywheel.. the 210mm unit is a nice upgrade.
yes, sachs stuff is generally pretty good quality..
Reply #17April 20, 2011, 08:28:36 pm
trent77
  • 217
« Reply #17 on: April 20, 2011, 08:28:36 pm »
where can i get the sachs stuff? I will also check out clutchnet.
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #18April 21, 2011, 09:42:16 am
« Reply #18 on: April 21, 2011, 09:42:16 am »
any aoto parts store should be able to get sachs super set clutches..
