Author Topic: Auto to Manual conversion: Audi 5000 TD  (Read 1929 times)
April 14, 2011, 06:36:00 am
mmitocky
  • 23
« on: April 14, 2011, 06:36:00 am »
I am currently converting my '83 5000 TD from the 3-spd auto to a 5-spd from a non-turbo 5000.  My question goes out to the few 5000 owners still left out there: those of you with manual transmissions (or conversions, preferably), how did you figure out your throttle cable setup?  The throttle cable from the factory went to a bellcrank on the side of the automatic transmission, and from there a linkage went up to the pump to move the throttle shaft.  Well now that the auto is out, I cannot see a clean, quick way to route a cable directly to the pump.  What did you guys do to make it work?
I recently bought a throttle cable from a 1983 Jetta TD (or something like that), just so that I had a factory-looking cable with an appropriate end on it, so it can attach to one of the ball studs on the pump.  I modified it to fit the firewall, and now I am going to have to build my own linkages on top of the pump to get a custom throttle setup....it seems to me that this has probably been done before, so I am looking for help from someone who has already dealt with this mess.
I can get pictures up in a day or two to help describe my problem.
Thanks guys,
Matt
Reply #1April 15, 2011, 04:24:11 pm
TPW
  • 113
Re: Auto to Manual conversion: Audi 5000 TD
« Reply #1 on: April 15, 2011, 04:24:11 pm »
I think you need to get a throttle cable from an Audi with a manual tranny.  It's a little longer so that it will reach the mechanism above the ip.
