Author Topic: Which trans to go with  (Read 5207 times)
Reply #15April 13, 2011, 02:26:30 pm
Re: Which trans to go with
« Reply #15 on: April 13, 2011, 02:26:30 pm »
Broke VW said the 85 up 020 all have the bad rivots. Before that the rivots were a lot harder. He said he drilled one out and it was next to impossible. The earlier ones had very little preload on the diff so they rattled. Later ones had a 20% kit basically. Brokevw site has all the info needed on that and he is better at it than me :D
Reply #16April 13, 2011, 03:33:58 pm
« Reply #16 on: April 13, 2011, 03:33:58 pm »
To remove I usually tap it and thread a bolt in then yank it out with hammer but thats my ghetto method!
That works really well... just need to watch for shavings, although they are brass and probably won't hurt anything in the long run anyways.
Because I always have the back off to replace the throw-out bearing I just use a long metal rod (that's a bit thicker than the pushrod) as a drift thru the hollow drive shaft...driving the bushing and seal out in one pass.
The new bushing goes back in first and is indented a bit to leave room for the seal.
Reply #17April 13, 2011, 04:07:43 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #17 on: April 13, 2011, 04:07:43 pm »
Parts ordered, whats the turn around time for that website fap99, thanks for the brokenvw link it got me just what i needed and it also gives me areason to buy a metric tap and dye set hehe.... ;D
Reply #18April 13, 2011, 04:11:25 pm
BigVWman
  • 332
« Reply #18 on: April 13, 2011, 04:11:25 pm »
If he has it on the shelf to MD i would predict 3 days, Maybe 2. If he doesn't he'll usually let you know when you can expect it.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #19April 13, 2011, 07:32:08 pm
« Reply #19 on: April 13, 2011, 07:32:08 pm »
In case this helps. Bushing: 020 311 107 B. Seal: 020 311 108
http://www.brokevw.com/020seal.html
