Author Topic: Mech head on Hydro block??  (Read 6456 times)
Reply #15April 17, 2011, 10:41:05 pm
Kantdrivefast
  • 196
Re: Mech head on Hydro block??
« Reply #15 on: April 17, 2011, 10:41:05 pm »
but i guess is what im wondering, is has anyone done this and successfully made it work?
dont know of anyone doing this, but i dont see why it couldnt be accomplished?
Did it, plugged the coolant passage in the head above the drain hole. Drove it for 11000 trouble free kms then parked it.
Its not that big of a deal.
Reply #16April 18, 2011, 06:12:11 am
wakeboard4life07
  • 29
« Reply #16 on: April 18, 2011, 06:12:11 am »
thanks. i guess i was just worried about cooling issues, since imma be running an hx35 with a big valve head and other goodies
Reply #17April 18, 2011, 08:50:09 am
« Reply #17 on: April 18, 2011, 08:50:09 am »
a mech head with big valves? why not just opt for the AAZ head? then you dont have to worry about plugging off ports that arent needed. an aaz head would bolt straight on a hydro block..
Reply #18April 18, 2011, 02:55:09 pm
UnderPSI
  • 109
« Reply #18 on: April 18, 2011, 02:55:09 pm »
Some people don't have an AAZ head laying around.
Suzuki Samurai 1.6
Reply #19April 19, 2011, 10:46:12 am
« Reply #19 on: April 19, 2011, 10:46:12 am »
but they have the money to build a big valve head? and obtain a HX35? i dont get it..
if it were me, i would find an AAZ head. i bet you could get one for under 150 bucks straight from canada..
they are far superior to a 1.6 head. its the best head you can get for an idi VW.. in stock form atleast.
Reply #20April 19, 2011, 08:40:13 pm
wakeboard4life07
  • 29
« Reply #20 on: April 19, 2011, 08:40:13 pm »
well the head work is pretty much free for me because my best friend owes me some favors and happens to build heads for a engine shop. All thatd id have to do is buy the vavles. it was a thought. I want to do the aaz head swap next summer, so the big vavle 1.6 head was ehhh just a thought. but i do have a bunch of mech heads laying around and no Hydro heads. that was the issue lol
Reply #21April 19, 2011, 09:12:54 pm
Kantdrivefast
  • 196
« Reply #21 on: April 19, 2011, 09:12:54 pm »
save the hassle and just get a hydro head.
Dime a dozen in the junkyard
Reply #22April 23, 2011, 07:56:55 am
wakeboard4life07
  • 29
« Reply #22 on: April 23, 2011, 07:56:55 am »
in maryland they are not a dime a dozen lol or i wouldnt have such a hard time finding one.
Reply #23April 23, 2011, 08:50:26 am
« Reply #23 on: April 23, 2011, 08:50:26 am »
Contact some people on the for sale section. Not free but I am sure there are people with parts that would come off them cheaper than you would think.
Reply #24April 23, 2011, 09:20:31 am
« Reply #24 on: April 23, 2011, 09:20:31 am »
hx35... good luck with that, hy35 maybe, hx35 no way
Reply #25April 23, 2011, 09:23:40 am
« Reply #25 on: April 23, 2011, 09:23:40 am »
thats kinda what i was thinking.. its gonna spool 100 rpms away from governor cut.. those things are HUGE!
Reply #26April 23, 2011, 12:27:00 pm
« Reply #26 on: April 23, 2011, 12:27:00 pm »
with one of those flappers that blocks off one of the scrolls at low boost he might be able to spool it up at a usable rpm, but i'm thinking it will surge like a mofo
Reply #27April 23, 2011, 01:05:28 pm
« Reply #27 on: April 23, 2011, 01:05:28 pm »
i dont see how one of those flappers can even function properly.. basically, if you have the right manifold for a twin scroll turbo, half of your cylinders will have no flow when that valve is closed..
Reply #28April 23, 2011, 01:15:23 pm
« Reply #28 on: April 23, 2011, 01:15:23 pm »
you only use that valve with a normal exhaust manifold
Reply #29April 23, 2011, 05:27:41 pm
« Reply #29 on: April 23, 2011, 05:27:41 pm »
I need to get up to Canada then because I've never seen one in a junkyard around here and I'm a regular at the local you-pull-it-yourself yard and a big one near L.A. In fact I don't think I've ever seen a VW diesel in there that's newer than like '83.
