Author Topic: Source for Oil Squirters?  (Read 7959 times)
Reply #15January 25, 2006, 05:53:26 pm
chrissev
  • 694
« Reply #15 on: January 25, 2006, 05:53:26 pm »
Quote from: "Northboundtrain"
Thanks, chrissev.  I need to start looking at the for sale posts more often.
The recent post on the SAE paper (which I read) was very enlightening.  Turns out that the TD engine is different from the NA in many ways.  I was not aware that the TD engine also has different/improved crank, main caps, valves, and swirl chambers.
Is it folly to try to build a TD from an NA without these improvements?  I'm particularly concerned about the valves and swirl chambers, so that would mean getting a real turbo head.  I didn't realize that there was a difference between the turbo and NA mechanical heads.
Yeah I've heard the turbo head has different valves and bigger swirl chambers.  You can buy a brand new 1.6 turbo head for $500 US but that might be a bit out of your price range.  Another option (and what I'm wanting to do if I can find one) is to install a 1.9 head.  These apparently give better air flow than the 1.6 turbo heads so they interest me a lot (it would mean I can pump more air into the cylinders, and pump it faster) and they also can be used with a metal head gasket which can hold more boost.  Add an intercooler and a ram air set up.....I am planning a summer project right now.....:)
Reply #16January 28, 2006, 07:28:46 am
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
« Reply #16 on: January 28, 2006, 07:28:46 am »
Quote from: "chrissev"
I'm assuming that a 1.9 head is has hydraulic lifters, so it would have to be on a '86 or later block, correct?
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
