Author Topic: Problem on Cold Start 1993 Golf GL Diesel  (Read 5151 times)
March 26, 2011, 12:03:37 pm
mcmonster
  • 2
« on: March 26, 2011, 12:03:37 pm »
I am having a problem starting my vehicle in the mornings.  It is not even cold out maybe -5 but car is parked in an enclosed garage.  I have replaced the 50amp fuse to the glow plugs, but when I try starting in the morning it will continue to just turn over and billow all kinds of smoke out of the vehicle.  If I crank for awhile several times, then eventually will fire up.  The glow plugs were all checked by my mechanic a few weeks ago, and they were all fine.  If I plug the block heater on the vehicle in and start in the morning starts fine.  Regardless if it has been running during the day, the vehicle runs great, there is only 160000 km on this vehicle and it is a 1993 golf gl diesel.  I am thinking that it could be a relay that is starting to fail. Anyone have any other things that I should consider?
Reply #1March 26, 2011, 03:12:21 pm
Re: Problem on Cold Start 1993 Golf GL Diesel
« Reply #1 on: March 26, 2011, 03:12:21 pm »
It certainly sounds like a glowplug system issue and it's fairly easy to troubleshoot with a test light or multimeter:
http://www.vincewaldon.com/index.php?option=com_content&task=view&id=41&Itemid=28
Reply #2March 26, 2011, 03:42:57 pm
mcmonster
  • 2
« Reply #2 on: March 26, 2011, 03:42:57 pm »
Thanks for the help vince, will give it a try.
Reply #3March 28, 2011, 10:55:49 am
« Reply #3 on: March 28, 2011, 10:55:49 am »
Verify the timing, your crank gear could be starting to spin
Reply #4April 08, 2011, 09:58:58 pm
mr.bbs
  • 4
« Reply #4 on: April 08, 2011, 09:58:58 pm »
don't those just snap + let loose?
Reply #5April 08, 2011, 10:37:26 pm
nathan_b
  • 361
« Reply #5 on: April 08, 2011, 10:37:26 pm »
no, they wallow out
Reply #6April 09, 2011, 01:03:27 am
« Reply #6 on: April 09, 2011, 01:03:27 am »
no, thats the timing belt that snaps and kills your engine..
