Author Topic: 1.5 turbo diesel Will it fit? Longitudinal mounting vs Transverse mounting  (Read 11454 times)
Reply #15June 15, 2011, 10:58:38 am
The intake and exhaust manifolds are different as is the oil filter flange, turbo oil supply line and turbo oil return.  I think you will have clearance issues.
Post a pic of the turbo side of the engine with the manifolds showing.  It looks like you have the longitudinal manifold on there and you will have interference issues.
Yes Andrew, it does appear to have a low mounted turbo..
Reply #16June 15, 2011, 07:13:54 pm
justmark
  • 7
I think it might look like a low mounted turbo because the engine is on the ground and is on an angle... From the techincal drawings i think it is definatly a "top mounted' turbo
here is another pic and you can see the turbo is clearly above the intake manifold
Reply #17June 16, 2011, 04:47:26 am
BillyWillicker
  • 111
Pics of each side of the engine from about 4 feet away would be best.
Reply #18June 17, 2011, 04:53:02 pm
justmark
  • 7
Awesome Thanks Guys...
Look like its back to the shed for me....
Cheers
