Author Topic: I bought an AAZ trying to comp test, what starter to use?  (Read 6053 times)
Reply #15March 20, 2011, 10:51:36 pm
coke
  • 254
Re: I bought an AAZ trying to comp test, what starter to use?
« Reply #15 on: March 20, 2011, 10:51:36 pm »
All 3 of my MK2's had gear reduction starters, and they're not nearly as big as the "direct drive" that my 84 and 83 had.
Reply #16April 25, 2011, 08:12:13 pm
erice1984
  • 263
« Reply #16 on: April 25, 2011, 08:12:13 pm »
I prefer a leakdown test over a compression test, especially if there are any issues with cranking the engine over.  Better info and easier to perform.
I agree with you here libby.
I tested the engine again tonight after putting pb blaster in the cylinders, seafoam a few days later and then filled each cylinder with about 2 cups of diesel and let sit for 6 weeks, then changed the oil.  I fear I may have let it all sit too long and possibly ruined some of my hopes for improvement.
My numbers are only slightly better.
Original: 300, 360, 330, 280
New: 380, 380, 300, 300
This was on a mediocre battery.  It was tested as being good, but definitely not the same one used as before.
Seeing how the test showed slight improvement I am going to just tear the engine down and give it a good rebuild, maybe re ring it as well.
I used approx 2 feet of 2 gauge wire from battery to starter unlike before using 12ft jumpers.
« Last Edit: April 25, 2011, 08:14:53 pm by erice1984 »
1980 Rabbit 1.9TD
